Long Travel upgrade.....
8T6K5
AZ
L98 350 TPI
My thoughts on the set-up:
100% improvement in ride quality. As I was thinking it, the GF said she noticed it.
On the F250 towers, if you are as anal as I am about symetry, do the passenger side first. With the fuel/brake lines running inside the passenger frame rail you are linited with your bolt placement. Meaning, you bolt pattern will not be the same as the driver side.
I had to re-route my remote starter solenoid wires as I had the running out a hole in the frame, which were more visable as a result of trimming the fender well.
Alingment? All of a sudden my alignment is off. Need to look into that.
Re-installing the top wasnt too bad. Good thing I dont plan on taking it off for a very loooong time.
Front end in done: completely rebuilt and now has 5" of lift.
Next major mod: ORD shackle filp kit.
I'm jealous how clean all of your parts are under there. And you drive this thing all the time?
8T6K5
AZ
L98 350 TPI
Ride my motorcycle to-fro work everyday, K5 just for running errands around town, camping ect.
Sent from my iPad using Tapatalk
Yah, could you imagine? :roflbow::roflbow:
Wonder what happened to the alignment, that is very weird. :think:
8T6K5
AZ
L98 350 TPI
Occured to me it might be the shims I removed, altered the caster which might have altered the tow.....
You just need to adjust the drag link to re-center the steering wheel. You're zero rates changed the angle on the drag link.
k5krawler
Auburn
nick
k5 blazer
hows that long travel?
8T6K5
AZ
L98 350 TPI
I'm using 11" travel shocks, but that's the thing with the Ferd mounts, you can cut to fit for any amount of travel you need. My guess is you could probably go up to about 14"
k5krawler
Auburn
nick
k5 blazer
well shocks dont give u travel for leafs, or are u talking about the shock stroke?
8T6K5
AZ
L98 350 TPI
Yes, the shock stroke is 11", was 7"
Useenamez
