Lets see your lifted trucks
77 K20
Montana
K20 5" lift
HT383 fuel injected
so I had an old and aged rough country 4" lift (spring up front and blocks in rear) on it before I went ORD. so that's what I'm comparing it against. I chose to go springs in the rear with a shackle flip for a couple reasons.
1. Stephen Watson at ORD said I should. and he knows square bodies lol
2. my springs were clapped out
3. I wanted 6" of lift. shackle flip is 3" and the ORD springs are 3"
they ride a million times better than my old setup. they soak up bumps like a caddy. I have not gone wheeling with them yet (I just got them installed yesterday). so I cant comment on flexing...but I suspect they will out flex anything I have had. ORD claims 14" of travel
they are 10 thin leafs in the pack as opposed to 3 thick leafs. so far I am incredibly impressed with them.
I am running tuff country 9000 shocks.
I did not move my front axle forward. the new spring packs pin is moved to the recommended spot which does appear to have moved the axle forward between 1-2". I did buy there offset plate and may install it in the rear so I can slide the axle back 1". but I wont be doing that until I get my driveshaft lengthened.
all in all it was expensive. very expensive. but I'm glad I went with there springs. I wouldn't do it any other way now that I drank the kool-aid
Thanks for that great info... one last question- could you do a quick center of hub to fender measurement on that?
colonel mustard
louisville ky
steven
k5 blazer
morning,
I'm out of town for work..however I just sent some measurements to ORD sunday. they measure lift by top of axle tube to bottom of bump stop bracket on driver side. it is 16 1/4"....hope that helps
77 K20
Montana
K20 5" lift
HT383 fuel injected
morning,
Yes, that is great- thank you.
Your truck is very tall. I've been thinking about a new lift. I'm only at 10.75" now.
@bucket your dually makes me :drool:! Its so fkn sexy!!!:hump:
Man, those old pictures make me sad. The dually could really use fresh paint now. At least it hasn't deteriorated nearly as much as the Suburban.
78C10BigTen
pennsylvannia
C10 BIG TEN
I bet its still sexy as is though!!!
BullyDog
High Sierra Desert
V10 Stepside
Finally done with outside restore.
goodwrenchca
