Lets see your lifted trucks
77 K20
Montana
K20 5" lift
HT383 fuel injected
so I had an old and aged rough country 4" lift (spring up front and blocks in rear) on it before I went ORD. so that's what I'm comparing it against. I chose to go springs in the rear with a shackle flip for a couple reasons.
1. Stephen Watson at ORD said I should. and he knows square bodies lol
2. my springs were clapped out
3. I wanted 6" of lift. shackle flip is 3" and the ORD springs are 3"
they ride a million times better than my old setup. they soak up bumps like a caddy. I have not gone wheeling with them yet (I just got them installed yesterday). so I cant comment on flexing...but I suspect they will out flex anything I have had. ORD claims 14" of travel
they are 10 thin leafs in the pack as opposed to 3 thick leafs. so far I am incredibly impressed with them.
I am running tuff country 9000 shocks.
I did not move my front axle forward. the new spring packs pin is moved to the recommended spot which does appear to have moved the axle forward between 1-2". I did buy there offset plate and may install it in the rear so I can slide the axle back 1". but I wont be doing that until I get my driveshaft lengthened.
all in all it was expensive. very expensive. but I'm glad I went with there springs. I wouldn't do it any other way now that I drank the kool-aid
Thanks for that great info... one last question- could you do a quick center of hub to fender measurement on that?
colonel mustard
louisville ky
steven
k5 blazer
morning,
I'm out of town for work..however I just sent some measurements to ORD sunday. they measure lift by top of axle tube to bottom of bump stop bracket on driver side. it is 16 1/4"....hope that helps
77 K20
Montana
K20 5" lift
HT383 fuel injected
morning,
Yes, that is great- thank you.
Your truck is very tall. I've been thinking about a new lift. I'm only at 10.75" now.
@bucket your dually makes me :drool:! Its so fkn sexy!!!:hump:
Man, those old pictures make me sad. The dually could really use fresh paint now. At least it hasn't deteriorated nearly as much as the Suburban.
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
I bet its still sexy as is though!!!
BullyDog
High Sierra Desert
V10 Stepside
Finally done with outside restore.
m4chine
