LED dash lights!
DanMcG
Central NY
k10 k10
Sweet, Thanks
lessersivad
Morenci, MI
Russ
1977, 1979, 1982, (2)1985 1985
C10, K20, K10, K5, K2500
On mine, I did the white overlays and the white LEDs.. Well worth the $32!
That looks nice!
I would guess these are easy to see during the daytime also.
I don't really have as much of problem with night time as I do during certain times of the day when the sun hits just right.
Then I can hardly see any of the gauges from the reflection on the clear lens and black background.
Thanks for sharing.
6.2crew
yelm
josh
k30
thanks for all the great info.
did the swap (partially) it is somewhat better, but..
some of the lights on the back of the instrument cluster were hardwired to the little twist out light holders. anyway, can you replace all of the hardwired ones with the ones you can just pop out the lights and replace.?
would like to replace them all. I really like the look. had enough left over to do the side markers and the running lights on top of the one ton.
thanks
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
thanks
Yep, you can get new bases that will accept removable bulbs. I replaced every single light in my cluster with a new base and LED bulb.
6.2crew
yelm
josh
k30
off to napa I go then!
thanks
ThSlug
Maryland
Matthew
Has anyone found some warm white LED that are dimmable? I'd like t stay close to stock look if possible.
ZC GMC
