Irishman999
- Jul 30, 2010
- Safford Arizona
- Jason
- K-1500 High Sierra
Big updates in my tool arsenal, still giving me a chubby.
First is the two tool boxes I got for 100 bucks off of craigslist.
We finally got a place with a garage, here is my 85 and the wifes Mustang in the driveway. I really like this place so far.
Last thing I am most proud of, wholly ****. I needed a parts washer so I made a wanted add on craigslist. Shortly after a guy named Will sold me one for 40 bucks. Great quality unit as far as I can tell, he said it needs a pump and it looked like someone bypassed a fuse and melted something.
Here is the parts washer.....
After I flipped it over and got the pump off I found the wires were broken, completely. That would be cause number one as to why it would not work. I pulled the pump out and found it was made in Hotrods stomping grounds of OKC.
The pump was cast aluminum and looked quality so I wire brushed off the tag to get some numbers so I could order parts. I found the parts through sears but nothing listed parts that were internal, only the impeller and impeller housing.
I decided since the replacement was 100 bucks I would try and clean all the gunk and **** out of my pump and see if it works. Basically all I did was clean everything really good with carb cleaner and re wire all the broken wires.
After a little work I was blown away.... **** works. This parts washer is an expensive unit and the whole reason the guy sold it so cheap was the pump not working. Really happy about this deal. I still have to get a couple things before I fill it with cleaning fluid and test it but the pump runs like a top when you plug it into the wall.
