Im stumpped
Paulscrawler78
Ahwahnee CA 93601
K5 blazer
5.7L
I'm gonna check the TV cable again in the morning before wotk
Paulscrawler78
Ahwahnee CA 93601
K5 blazer
5.7L
I think I may have figured out my issue its related to the TV cable because when I pulled the cable free from the tb it seemed sticky which would lead me to brlive I have it in a bind because its hard to move by hand i readjusted it so now I'm going to go for a test drive I'll report back later
Paulscrawler78
Ahwahnee CA 93601
K5 blazer
5.7L
So went for a test drive and it seems I have the transmission fixed again but I noticed the adjust keeps undoing its adjustment also still seems like the cable is binding so I'll pull it loss and reroute it and hopefully that takes care of all the issues I'm having
At least you're on the right track. Does the type of calbe you have, the one with the adjustment lock at the TBI end? If so, make sure it's locked down so your adjustment is not moving.
Paulscrawler78
Ahwahnee CA 93601
K5 blazer
5.7L
Its the same cable as autorock.com the shift points thus far is 1st to 2nd is at 26-28mph 2nd to 3rd at 38mph but no od thus far
Paulscrawler78
Ahwahnee CA 93601
K5 blazer
5.7L
I do have the one that locks and it looked like the cable was bound up because it is really hard to move so I re ran the cable after work tonight I'll do some adjustments on my way home tonight and see if I can get this bitch to adjust the way I need it to
Cool. Good Luck. Hopefully you're about to get this issue to rest once and for all. At least on the right track now. :waytogo:
Paulscrawler78
Ahwahnee CA 93601
K5 blazer
5.7L
I'm hoping so because I would hate to have to put this back on non op till I can have the trans rebuilt or just walk away before I lose my damn mind with all the issues I've been having
Naww, I don't think the trans if to far gone at all. Reason being, you're fluid is staying clean you said, and the pan had little or no sludge or metal shavings in it. I think the prognosis is all good, with the proper diagnosis, and I think you're all over the diagnosis with a good treatment plan. It's gonna work out. I feel it.
Paulscrawler78
Ahwahnee CA 93601
K5 blazer
5.7L
Man I hope your right I've been fighting this truck for 3 months now and its just been one thing after another with it and its just wearing me down and I've never in my life let a vehicle beat me this bad I would always get rid of them the first sign of trouble but everything on this truck has come to me for a reason and hopefully that reason shows its ugly face soon lol
Paulscrawler78
Ahwahnee CA 93601
K5 blazer
5.7L
So I have an update for you hotrod I reran the cable went to do the base adjustments as we talked about a few pages ago and when I go to pull the throttle by hand the thing is almost impossible to move and when it finally does move it pulls the adjuster have way out and when I go to test drive the truck I still have bad shifts at high rpms and still no over drive so what I think I'm gonna have to do is pull the damn pan off one more time check the rocker arm thing and make sure its touching the valve arm and also could I pull that valve pin thing out and check for any plugging or score marks on it to make sure it move freely inside its bore or would I screw something up really bad by doing that and also should I pull the governor out and check it as well
If you get everything out of the way and have enough room to pull the valve out, you won't hurt a thing. Probably a good idea to do so. It could have a POS in the bore and making the valve sticky, buy pulling the valve out you'd dislodge anything in the bore. Don't lube the valve with anything but trans fluid. That's all it needs.
Paulscrawler78
Ahwahnee CA 93601
K5 blazer
5.7L
OK cool so I am in the right direction then as far as what to attempt to try to fix this **** nugget
Paulscrawler78
Ahwahnee CA 93601
K5 blazer
5.7L
So tomorrow as long as it don't snow I'll be pulling the TV cable to check it because its extremely hard to move so something don't feel right then if need be I'll drop the pan and look at it agian
SidewaystheSeven
