Im stumpped
Paulscrawler78
Ahwahnee CA 93601
K5 blazer
5.7L
Ya I'm always really lery about paying for anything online I even got hosed by PayPal so I may have found one at a different store so I'll try there first
I posted the Rock Auto part # in this thread.
I would replace the cable regardless unless you can 100% confirm that it was NOT stretched either the cable itself, or it's housing or both when it was hung up when pulling the motor and trans. For a 700r4 that relies heavily on proper adjustment or trash the trans, it's not a risk I'd want to take.
Though he mentioned it's kinked, so it for sure needs replaced.
Paulscrawler78
Ahwahnee CA 93601
K5 blazer
5.7L
Ok perfect I'll be replacing it at the fluid as well as checking the ticket arm thing for any damage also its supposed push that valve all the way in correct
IIRC, Yes. I think you'll be able to tell if the linkage is bent or not. Being the cable is the weak link there, I'd imagine the cable PROBABLY took most of the damage if any. Just give it a good visial looking over, and by hand move it, make sure it's moving freely and returns freely.
Paulscrawler78
Ahwahnee CA 93601
K5 blazer
5.7L
The transmission fluid was ugly motor oil consistance got the TV cable yesterday went to get transmsission fluid will take pictures of the arm when I get back
Paulscrawler78
Ahwahnee CA 93601
K5 blazer
5.7L
After cable replacement and straightening the rod that connects to the TV cable
Paulscrawler78
Ahwahnee CA 93601
K5 blazer
5.7L
Before TV cable replacement and rod repair
Paulscrawler78
Ahwahnee CA 93601
K5 blazer
5.7L
So the transmission shifts like she's supposed to and all seems fine minus some cable fine tuning
Great News. So then it was a stretched cable from the engine pull. Hopefully the permanent damage was kept to a minumum. How much sludge was in the bottom of the pan? Now much metal flake? Usually a tab bit of aluminum looking shavings, and a bit more brass colored shavings can be considered somewhat normal if had never been apart before.
Paulscrawler78
Ahwahnee CA 93601
K5 blazer
5.7L
The first time I pulled the pan very very very little and when I pulled it off this time none at all even after driving it for a week with jacked up shifts the only issue I'm having with it now is the od will not kick in till 60mph
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
You getting any VSS codes?
Jims86
Patterson,Ca
5.7 TBI
Hmmm...they are usually programmed to lock at around 31 in 3rd, and 38 in 4th.
SidewaystheSeven
