bluex
- May 9, 2013
- Spartanburg SC
- Paul
- C15
I don't think in this case you could assume they would've found a simple valve body issue and restructured the bill accordingly. I didn't want to get into it as its a rather long story.
My assumption was that they (the dealer) have this national database with my specific vehicle history and they're the ones most qualified to access that database and then do the repairs. Shame on me.
To quote Paul Harvey..."And now, the rest of the story".....
I did have the second dealer diagnose the issue. They said all the wiring and everything outside the tranny was good but there was definitely something wrong in the tranny. It cost me $125 for that diagnosis.
If I wanted to do T&M to try and fix it they would do that but they insisted that their standard operation for anything more than 100k miles is to remove it and open it up before quoting me a price to repair. That would be 8 hours labor at $100/hr to get me that quote plus the associated T&M to repair. If I decided I was not going to proceed it was still going to cost me a minimum of $800.
I specifically asked about just dropping the valve body to inspect based on the national repair records being a known issue before and was refused. Again, their reasoning was it had over 100k miles and not their standard operating procedure.
This is the point where I was totally pissed. No matter what I did, it had already cost me $125 for them to tell me there is a problem in the tranny.
So I could give them another $800 for them to tell me what was wrong and how much above and beyond that price would be to repair.
Or just give them $2700 to R&R the tranny.
After I removed the valve body and saw the problem I took it over to a good friend who's a Chrysler mechanic who specializes in trannies. I knew that there was no way that he would know a Ford tranny or if that was the problem for sure but he did confirm that it could certainly be a problem or a part of the problem.
I told him what the dealer had told me as far as the discovery process and he said....in the dealers defense....that any Chrysler dealer would probably do the exact same thing with any vehicle over 100k miles. That's the way our society and bigger businesses have evolved.
I have to assume going to an independent shop would've been a much more pleasant experience. I'm sure explaining this story they would've easy dropped the valve body and found the issue in a few minutes as I did. You just don't assume they have a Ford certified tranny tech on staff and your only option is a dealer.
So you're absolutely correct. Our culture has changed. People would rather spend $600 monthly to ensure they have a warranty then worry about dealing with these kinds of issues. Vehicles are more throw away now then "drive until the wheels fall off". Most people don't know what it really takes to repair these cars today and they don't want to know. They just want it to work and when it doesn't they feel they're going to get screwed before they even come into the shop.
Its also a problem when you only hear about the bad examples like this one. I have several more that I could get into. I also have some fantastic success stories from dealers as well as independent shops that really took care of a customer the right way. Unfortunately, you don't hear much about those.
You're exactly right because the service advisor sold you a new a trans an thats the work order the tech would have gotten. They only do whats on the work order so they probably wouldn't have even dropped the pan.
