adamv7010
- Jan 18, 2012
- nc
- adam
- k10 silverado, k10 suburban
Had to change the output seals in the t case...didn't put it on the lift...figured it would be just as easy in the ground since the trucks lifted and all..at any rate...pulled my chocks out...sat them by the rear tires...went to set the parking brake and my phone rang...finished my conversation and went to work draining the case...
Next step...removing the rear drive shaft...note you read nothing about going back to set the parking brake OR chocking the wheels...yea you know where this is going...
Popped the rear drive shaft out...and in that split second...truck began rolling backwards...im under it on a creeper...and yes it literally ran over ne...I couldn't seem to get out from under it...it happened really fast...
I managed to ride the creeper while hanging onto the t case crossmember...onto the grass off of the pavement...scurried around and saw the left front 35x12.50 coming at my head...rolled my body and that left front tire rolled over me...literally...by this time I was on the front side of my body on the ground...ran over my legs between my ass and the back of my knees...
I truly feel im lucky to be alive...a few inches one way ans it was ny head and the tire...a few inches the other way and it was my head and the bottom of the differential...
I use no exaggeration here guys...this was honestly the second time in my life I truly feared for my life...
Always take the proper safety precautions when doing your own work on anything guys...
