Huck's daily - 2005 Z71 crewcab
Back on this today. Decided to do some learnin' since I've already been down this long, what's another day or so for educational purposeseses?
When we left off, I had .026 worth of shim on the pinion and .2535 RH and .2225 LH carrier shims. I decided to start the day with taking the .0105 shim off the pinon and just run .016. The OE was .036. I figured this would throw things pretty far off...the pattern improved :oops:
Ok, so we'll stick with that. But backlash opened up to .013-.014. So I figured I'd move the carrier toward the pinion .005. Couldn't make that happen with the shim choices I have, but I did have a .0075 shim in this stack I could move. So I used that, moved the carrier over .0075. Started with checking backlash before painting/running a pattern.
Most spots where .006-.007. But I did have a section that was .008-.0095 and another that was .004-.005.
Here's the tight section. It's weird cuz it's only 3 teeth, it's .006 on one end and .008 on the other but .004-.005 in between. Thankfully, this is 180* from the .008-.0095 section, so I'm gonna spin the ring gear 180* on the carrier and see where I land. I'm eating lunch now, I'll update later
Lost 1.5hrs shooting the **** when a buddy came by, fiddled with some shims to see if I could cheat rather than flipping the gear. Could not, so lost another hour going into town to Home Depot for a map gas torch and dinner. Got the ring gear off and flipped, waiting for it to cool now
Well, got it back together again. The ring gear is still 100*+ so I’m taking all of this with a grain of salt and not making any more changes until tomorrow.
The backlash has a smaller range now, .005-.007 but I still have a tight section and a loose section. The good news is, I think (if the BL doesn’t open up once everything is the same temp again), I can just make a ~.003 change to the carrier shims and be pretty good. I sure do hope so anyway. I’m ready to drive this thing again.
jwilson
