How to mount 1983 (O-ring style) PS pump on 1975 K10
Useful
Fayetteville GA
I put a Borgeson steering gear and crossover steering in my ‘75 K10 but the fittings kept leaking. So I bought a 1983 version PS pump w O ring fitting because I heard they seal better.
The problem is that the pump is clocked just a little different such that my PS reservoir interferes with the Waterpump and won’t allow me to tighten the belt. Any ideas for a solution?
1lejohn
texas
john
k-1500, 2500 HD
With out pictures I would only be guessing. Drill some new holes in the bracket? Are you using the new pump bracket, or the old pump bracket?
Useful
Fayetteville GA
I’m using to old bracket and it won’t let me pull it to the left enough to tighten the belt-or even get the second bolt installed.
Robert Bare
MT
Robert
k20
Which "fittings" kept leaking?
Old Guy Bill
KY
Bill
Get a longer belt…
nvrenuf
Mobile, Al.
I know they make adapter fittings to go from flared pumps to o-ring fittings but I'm not sure about the other way.
Put your newer fitting in your old pump,they unscrew out of the pump. Then you can have old pump new Oring. lines
Turbo4whl
Downingtown, PA
Wayne
So unless the SAE tube flare is damaged, you should be able to get it to seal. GM used them for years. That being said, you could mount your old pump. Swap out the relief valve from the '83 pump into the '75. Now you will need the correct pressure hose with the 'O' type fitting on the pump connection.
Useful
Fayetteville GA
Ok, man that’s pretty simple. Thanks!
I was going to swap the reservoir to the new pump but that sounds a lot easier.
Where did you get that ps cap?
The reservoir wont change the fitting or what lines go into it, the pump itself has those. If you want your nice new pump body and cap on your old pump, go ahead. Just get new o ring incase the o ring is damage removing the reservoir.
Useful
Fayetteville GA
It was just a pump off Amazon-modulus power steering pump. Will get O ring. Thanks for the help!
Confirm the vent in the cap works by blowing into the stem at the center at the bottom, if you can bleed air slowly through it this way, its a good cap
ali_c20
Austria
Alexander
C20, K5
Welcome from Austria. Nice truck, hopefully without leak soon.
:welcome:
armchair
