Homemade and modified tool thread
Bike carrier,turned into duckhead Tire mount. Works awesome!
hoagster
California
K10, 1500
5.3l
I had one of those bike carriers what a pos! My 80 year old neighbor now uses it to drag his trash cans out to the pickup spot with his side by side!
legopnuematic
Licensed Junk Dealer
MO
Spencer
Here are a couple.
Hillbilly hones
"Spanner" socket for a nut on the motor on the Oliver wood lathe
Heat shrunk extension for a countersink. Made it to chamfer the lifter bores on my slant six.
These two are more techniques or tips I guess.
Using press to hold carrier to tighten ring gear bolts
Running a bead of weld on a bearing race to shrink it to remove from a bore.
legopnuematic
MO
Spencer
Axle seal install rig for my Dodge Dana 60 front
Axle tube scraper
legopnuematic
MO
Spencer
Cab lifting beam for use with cherry picker
Cardboard laid out to mark mandrel bends to cut them correctly. Also 3d printed mandrel bends mockup pieces.
Tig filler rack
Low profile tap extensions.
legopnuematic
MO
Spencer
Pinion setting tool. I only had my time I to making it, I'd honestly recommend just getting pinion depth set by trying shims and reading the pattern with setup bearings.
Especially we with how much the commercial ones cost.
Here are a couple.
Hillbilly hones
Where be this slant six you speak of?
legopnuematic
MO
Spencer
In my Dart, 71 225/auto
Love it! Is that a Clifford intake and headers?
legopnuematic
MO
Spencer
Thank you.
It is an older Clifford 4 barrel manifold, Aussie cast Dutra Dual split manifolds, Quick fuel 450 carburetor, JP performance true double roller timing chain, Oregon Cam Grinders custom ground cam, .100 machined off the cylinder head for a little compression, 5 angle valve job. The valve cover is a low production cast piece from Argentina. Later electronic distributor triggering an HEI module and vortec coil.
Thank you.
Very impressive! Thanks for sharing. I got a special place in my heart for these motors. Had several.
Ran across this slick cab lift attachment,to go on a cherry picker on another site. Anybody seen one for lifting the front clip?
Socket Stringers. This morning I had an idea,this is the rough draft. Socket stringers you can throw in a backpack and when you get to the junkyard all your sockets are in one place and in order instead of knocked off Socket rails and laying in the bottom. Will make color coded for metric vs. Standard and finish the ends better this was the prototype. I have decided a backpack will be a cool pik n pull toolbox. So putting one together out of left over junk tools,so I can walk out carrying tools on my back, parts in my arms or hands or prowl the yard without rolling a wheel barrow or carrying a bucket or toolbox in my hand the whole time. Sorry forgot pics earlier.
RoomForSquares
