Help me identify a vibration
Carb'ed Vortec 350
That may cause some noise...lol...
yevgenievich
Place
Name
Year
Model
Size
Figured out the issue with the "cracking" sound up front. Turns out something WAS cracking, just not quite what I thought. See anything odd here?
Looks like somebody with little hands decided to play a trick on Daddy while the truck was getting its driveshaft fixed...
Dang kids.
Was that cause for noise and vibration or noise only?
da_raabi
Trailer Park Supervisor
FloriDUH
Adam
c30
It was the cause of the cracking noise only.
I drove to work today and the vibrations is still definitely there. It's like a buzzing.
I noticed when I pulled the d/s that there was a lot of play in the pinion. Not up/down or side/side. Rotational. As in there was slop in the gear and I could turn the pinion a bit before the wheels stopped the movement (wheels were on the ground). My Dad said that was typical/normal, but that does not seem right.
Should there be a lot of rotational slop in the diff?
Carb'ed Vortec 350
I've had them with rotational slop and without. But ones with slop didn't cause a vibration.
peats
Pennsylvania
john
k5 c10 k10 SSR doodlebug
406 360 6.2 5.3 171
i'll just throw this out there because it happened to me and was very hard to find. previous owner had done an engine/trans build/swap and the truck had a tremendous driveline shake. i eventually discovered that the torque converter bolts were mismatched and not of the same weight. maybe not your particular problem but an easy thing to check
89 burbarian
ontario canada
chuck
suburban sle 2500 2wd
454 tbi
nobody mentioned It could be your harmonic balancer rubber is cracked / dry rotted?
da_raabi
FloriDUH
Adam
c30
You I actually talked about that with my Dad. I'm pretty sure the balancer is the original @ 150k miles... Would there be any other symptoms?
89 burbarian
ontario canada
chuck
454 tbi
I personally wouldn't know but sometimes my burb shakes at 80k and the passenger seat is a wobbling ,itry to speed up slow down hit the passing gear to see if it changes just had new caps and chrome lugs installed new high pressure valves rotated and balanced but only drove a few kms so I haven't checked to see if it was gone, big heavy tires stiff frame harmonics is playing a tune
fussfeld
east coast
j
c-10
4.3 v-6 262CID
Road forced balanced by who? Do you have the printouts?
Are the all the tires round?
89 burbarian
ontario canada
chuck
454 tbi
lol,who you kidding, a decent mechanic did a balance that's it,did you get your camera on that balancer yet?
89 burbarian
ontario canada
chuck
454 tbi
I wasn't present during the removal of the tires to clean the beads but I have put 15.000km on these wildpeaks and didn't notice any up and down at any speeds just sometimes she gets the shakes 265 75 16 e rated they are pretty quiet too
Craig 85
Nashville, TN
454/TH-400/NP205
I has a similar issue with an '87 C30 crew cab back in the early 90's. When I bought it I had this chirping sound when you would start it. It turned out it had loose torque converter bolts. So being young and dumb I just tightened them and kept driving it. I would get a harmonic sounding vibration at about 65MPH. My guess the hole got oblonged from being loose. I can't confirm that was the issue as I sold the truck within 6 months.
da_raabi
FloriDUH
Adam
c30
Well I'll check torque converter bolts too. When I rebuilt the trans I installed new ARP bolts and used lok-tight on them, so I can't see that being the issue. But you never know.
If only this rain would quit...
dc3725
North Dakota USA
Anton
All I can say is they may be unbalanced tires
Rusty Nail
Rusty
350sbc
Geez, I read the whole thread...annnnd after all that I should have said the same thing I thought after reading the original post!
BUT! I figured it was necessary because I didn't want to look like a ********* and repeat something that's already been said. Yet somehow, I still ended up looking like a doucebag, lol.
Anyways!
My first thought was "lemme guess? 45 m.p.h.?
"and only 45 m.p.h"
Ah hah!
Maybe my first hunch is/was correct?
Omg. It's a 1986?!
Okay. This is worth examination.
Wait!
You rebuilt if yourself? I think this may the right tree.
AND 70?
Hmmmmmm....
Okay dude...my FIRST thought was T.C.C.
T.c.c. solenoid?
Yeah....probably...at least maybe? Be sure to check that plug & wiring too!
Transmission fluid level-WHEN hot!
2manysquares2care
