harmonic balancer bolt?
mikeoverland
san antonio tx
michael
250/I6
Greetings all! I am in the process of replacing the harmonic balancer on the 250/I6 and i have a stupid question. Does this motor have a crank snout bolt that needs to be removed before i pull the balancer? I have looked, prodded and poked and I can't find one. I was going to pull the balancer and replace that and once that was done I was going to replace the transmission but if i have to pull the motor to fix a broken crank snout bolt........... Please let me know
350 w/203
Only the high-performance small blocks had a bolt. You'll need to use a puller (borrow one from your auto parts store).
This tool can help you thread the crank for a bolt;
mikeoverland
san antonio tx
michael
250/I6
th
that explains why there isn't one there...... Thanks for the assist and the advice.
Maybe I’m getting confused, but I think my original ‘75 engine and my GM crate 350 both had a bolt into the center of the crankshaft. It also has three smaller bolts to hold the fan belt pulley on.
350 w/203
We're talking a 6 cylinder here.
JBswth
Vallejo, California
James
C25
292 cubic inches
My 292 has center bolt, but most of the 250s I've seen do not.
J. B.
Rickf
Grafton NH
1974, 1954 & a 1937
All of the GMC inline sixes from the 50's that I have use crankshaft/balancer bolts.
Carb'ed Vortec 350
My 1966 292 has the bolt....
square-up
