RanchWelder
- Jan 14, 2023
- Earth
- Blazer
- 355ci
My new engine is a 98' Vortec Block.
Noticed the Harmonic Balancer is identical the one I used previously on my 1994 Casting SBC 355HO.
Read the reluctor wheel causes the Balancer to move out 1/8" from the crank timing gear. Other than that they are the same.
My previous engine had the standard steel timing cover. No reluctor.
Is this the case?
Which cover did you use in this situation and why?
Delete the reluctor for good, or fight the spacing and try to keep it for later?
What do you guys know?
Is this the case?
