Matt69olds
- Jan 8, 2018
- Central Indiana
- Matt
- GMC 1/2 ton
- 455 Olds
Did some routine maintenance on my sons 92 Yukon, noticed the rear tires turn opposite from each other when rotated by hand. Classic example of a open rearend. However, the RPO code shows G80 which is locking differential. If I remember correctly, these trucks have the dreaded Gov-bomb diffs. Has this one already exploded? Or does it take a certain amount of slip for the diff to lock?
Is there a better junkyard diff that will bolt into this rearend? This is a half ton Yukon, I assume it’s the common 8.5 rear that other half ton trucks use.
My son has big dreams for this truck, just as we all did with our first car/truck. I’m trying to drill into his head the lowbuck but do it right mentality. In other words, build the truck the right way, but as cheaply as possible.
