Fuse block connectors
Terry Wilkerson
Kansas
Terry
GMC 1500
I'm lookin for fuse block connectors for added circuits. Anyone have a number or source for the correct ones. My truck is a 1986 gmc.
dsteelejr
Hudson, WY
I presume you’re asking about the accessory slots on the front of the fuse block and not the connectors that go on the back side for the fuses to plug into?
You can use any garden variety male spade terminal to plug into it. If you are looking for the plastic connector piece that locks in place so it doesn’t fall out that would be part number 12004892 (multiple wire) or 12004888 (single wire).
Rickf
Grafton NH
1974, 1954 & a 1937
What will you be adding? A #10 wire from the battery and an ignition activated relay maybe in your future.
legopnuematic
Licensed Junk Dealer
MO
Spencer
My 76 I added a 10(?) circuit fuse panel to run my accessories and to correct a few wiring issues from the previous owner. Have a 70 (I think) amp constant duty relay powering the block and triggered off a switched ignition connection on the original fuse block. Power fed from the terminal block on firewall.
Did that back in 2020 and still works excellent.
The fuse block also has a ground bar, which is nice to have a solid and easy point to ground too, for installed equipment and troubleshooting with a test light.
Terry Wilkerson
Kansas
Terry
GMC 1500
Added constant power for Dakota digital, radio constant, and fule pump relay. All low power. Oh and dome light. Dome light was not hooked up who knows why.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
new73chevyjob
