battery junction Block issue ( see photos)
Dejure
Eastern Washington
Kelly
C15
And, on that fuse link thing, if it were a hot wire, I'd give serious consideration to installing one, if there wasn't one already.
Decades back, I experienced a shorted wire that all the insulation melted off of. Had the truck had a fuse link, that wouldn't have happened.
I appreciate the responses and I am a bit skeptical in regard to my actual "need" for this junction block. The 12V+ source for this junction block comes from the starter where it is co-mounted with the 12V+ from the battery through another junction block. I am thinking to just eliminate this junction, and directly wire it to the junction block approximately 1 foot away!
where are you putting your fuse panel from your donor?
RiverRat4
north coast ohio
r0d
vortec LS-2 5.3L
The replacement wiring harness fuseblock is under the hood on the firewall. Not ideal but it was there when I bought the truck. The CPU is out there as well.
brad083
