Fuel Lines for FI
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Did you use the remote sump or in tank pump?
If in tank, tsk-tsk, lol! Holley specifies a 3/8(-6AN) for the return too, iirc. My factory return was 5/16”. In all reality I’m sure you’re fine. In fact, I think I contemplated reusing the factory lines, but it hadn’t run in a while and I was worried about crap in the lines clogging my injectors as well as the crap e10 fuel eating them up.
In tank fuel pump :)
The... Acdelco... EP381 I believe.
The holley efi uses 6an send and return.... I just retained the tbi's original 16mm and 14mm send and return lines, and purchased adapters.
Seems like the return just dribbles.... Not very substantial pressure.
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
You probably return quite a bit less with the 502 than my itty bitty tree-fitty!
Vbb199
Salisbury NC
Vince
It's a thirsty bish.
It drinks a gallon of 93 or whatever the highest octane I can get locally is in about 25 minutes or so.
jimlayhee
