Filling a k10 wheel well, best wheel to tire ratio
Dutch Rutter
Independence, Or
Joshua
Tough looking truck brother.
It looks like all the cool kids are staying in the 15, 16 in wheel range.
I think if your wanting the tall and skinny look a 12.5" wide might be too much. Once I wear out these tires I'm planning on going to 305x70r16 still keep the near 33 tall yet a bit skinnier then the 12.5s. Your wheel width will also play in a little.
Fireturck's 33x10.5 above look really good for a stock height setup. :waytogo:
RoryH19
Rory
R10 Silverado SWB
Here a picture of mine with the 33x12.5 0n 16.5s truck has 2" or so of lift.
Second picture is the same truck with 265x75x16 (summer tires for now) definately look a bit goofy compared to the 33s.
I'm not sure if the year differences make an impact on this or not. Probably it being a k20 makes a difference.. forgot to mention that.
I run 33x12.5r15 on my 82 K5 with a 3 inch lift. No rubbing with AT or MT tires. I've had both on there.
RoryH19
Rory
R10 Silverado SWB
Nice thought, but I do not believe so on a '79, although they certainly could have upgraded.
:p
Still partial to the round eyes, but that 80 Chevy grille with the squircles sure looks good !!
79 and 80 share the same grill. A 79 would have round eyes unless changed by the owner. 80 is the only year for the squircle.
FireTruck1984
Michigan
1984 and 1984
I'm in the market for some new tires, and possibly some different wheels for my 79 k10. Im running 31/12/15
at stock ride height, and they kinda look silly IMO. I'd like to fill the wheel well a little more, and I like the taller, thinner tire look. Plus I'm hoping to get a little better mpg out of the thinner tire.
From what I've read, 33 inches is the max my wheel well can fit without modifications, so I found a couple different wheel/tire options I could go with.
I'd like to see some pictures if possible, and hear some opinions, of different wheel sizes with tires that fill my wheel well.
33/10.5/15
255/85/16,
255/85/17
275/70/18
245/70/19.5
Any pictures of these would be greatly appreciated.
Here’s 35 12.5 15 ( photo from another member ) this size would probably work on your truck since your front appears to be lifted. You could level it with a 2” rear lift ?
ghopp24
TN
Greg
I have 33x12.50.15 on 15x11 wheels with no lift on a 1986 K10. Plenty of room.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
285/75-16
theoretical 32.8” or “metric 33”
Maybe a higher contrast picture, but the true wheel gap may not be accurately represented with a trailer and slight flex in the front.
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
Amazing how that works - 33 x 12.50 x 15 Kumho Road Venture M/T with a 4 inch lift and I hear rubbing on tight turns.
Not sure where, but it does.
32.76 inch on wheel, inflated.
https://www.discounttire.com/buy-tires/kumho-road-venture-mt71/p/88264
Well, hell.
Which is it ?
What I have is the top pic.
Says it is replaced, and the diameter is 34.8 inches.
nickdaddydollar
Knoxville tn
Nick
Those wheels look perfect! Thanks for the picture.
80BrownK10
Greenwood, SC
Nate
:p
79 shared the same trim type rings just had round headlights. The same headlight trim fit the 80s without the square headlights which there were some made. Non Silverados and the special sport package were only ones that got the squares.
I have an 80 as well.
80BrownK10
Greenwood, SC
Nate
Nope 80 is a one off year. It's the only year with the egg crate small square opening grill. Now they bolt up to each other yes.
80BrownK10
Greenwood, SC
Nate
Well, hell.
Which is it ?
I have 1.5-2 inches of lift I believe, maybe a 3 inch block in back, I need to measure it.
I am running 33x12.50x15 on the factory rallies and I have no rubbing. I have a set of summit trail climber at on when I bought it and they were same size with no rubbing.
RogerioHR
