Evaporative emissions equipment
8lugburby
florida
Mark
r2500
I'm having trouble with my tank getting into a vacuum on long trips and I'm sort of confused as to what the evap system consists of on this old truck. I understand how a modern evap system works, this one is foreign to me. No purge, or vent valve, no fuel tank pressure senor. The vapor canister up next to the radiator has one 1/4" hose which I tested to flow freely back to the tank sender, one directly to ported vacuum on the throttle body and one 1/2 or 3/8" barb which was just vented to atmosphere with a simple baffle over it in my application.
I've used a hand operated vacuum pump to verify all lines and canister itself flow freely. does this truck use a vented gas cap? what exactly am I missing here. truck is a 1991 r2500 suburban, with California emissions equipment RPO code. from what I can tell the California emissions simply consists of plastering a pellet style cat directly after the muffler, kind of funny. no air pump or anything.
gmbellew
Kansas city
glen
suburban 1500
make sure the lines are hooked up correctly at the cannister and throttle body.
gas cap is supposed to have a check valve in it to relieve pressure or vacuum. so it could be a bad cap.
8lugburby
florida
Mark
r2500
thanks for the info. exactly what I needed.
so a regular "emission control" style gas cap will have the proper relief or is it something particular to the older model?
maybe1day
