Engine oil lines.
BryanS
Ft Pierce FL
Bryan
Blazer K5
I think you're overcomplicating this. Flare the existing metal lines and run fresh metal lines or AN call it a day.
I wouldn't remove a cooler, nice to have such a thing.
That’s where I’m at. Plus it give me an excuse to buy pretty stainless hoses
As for your flexplate cover,a 4x4 cover is cast and has bosses for braces to attach to. Your missing the braces also. At this point a 2wd cover is better than nothing,until you find braces and a 4wd cover. I actually ran with no cover in the past,I ran over a basketball I didn't see and wound it up in the flex plate,yes,something is better than nothing
BryanS
Ft Pierce FL
Bryan
Blazer K5
As for your flexplate cover,a 4x4 cover is cast and has bosses for braces to attach to. You’re missing the braces also. At this point a 2wd cover is better than nothing,until you find braces and a 4wd cover. I actually ran with no cover in the past,I ran over a basketball I didn't see and wound it up in the flex plate,yes,something is better than nothing
Describe said braces :) they go on the outside of the cover and attach to what?
chris3353
idaho
chris
v2500
I run rubber the entire length,, Used automotive flare fittings at the cooler and filter.. Installed Gates hose rated for oil and pressure.. been that was for 200K miles
K5 Blazer
Sant Cruz, CA
Holden
K5 Blazer
6.0L LS
I am in the camp that the oil cooler is overkill unless you plan on doing heavy hauling. I did an LS swap on my blazer and deleted the oil cooler. I feel my application is a lot lighter than what that application was originally designed for. If you plan on keeping the cooler, I would change the fittings to AN and make AN lines to the cooler.
Old Guy Bill
KY
Bill
Lots of info out there on those old big blocks with those fittings.
Small plugs (like freeze plugs) or tapping them for threaded fittings was usual way back in the day.
BryanS
Ft Pierce FL
Bryan
Blazer K5
Dead link here's a pic I stole from @SquareRoot
Thank you
Yes that’s it. What are the braces bracing? Like keeping the cover in place? Or supporting the weight of the tranny?
Looks like they bolt to the frame or crossmember? I would think the 6 bolts would hold the cover on?
RalphF
