Engine Backfire Diagnosis Led to Wiped cam Lobes
Skweegle89
Oklahoma
85swb "Fancy"
It is cold as **** outside and I forgot to get propane for my shop heater today. There's nothing like busting your knuckles when it's 20 degrees outside.
350runner
tx
Ceasar
No worries. It's freezing down here too. Good thing that wind stopped
Skweegle89
Oklahoma
85swb "Fancy"
Last time I pulled the cap the rotor was shot. That was about 150-200 miles ago and it hadn't been on there very long. Granted, the PO had the plug wires in the wrong spot.
350runner
tx
Ceasar
This is what your checking when you a are twisting the rotor... under the rotor the is the center plate and two weights on the outside of that.
distributor mechanical advance: http://youtu.be/oxgmCXeIVZo
350runner
tx
Ceasar
This is not an hei distributor but still the same principal. Distributor Advances (Part 2) - Vacuum & Mechanic…: http://youtu.be/cFfnenMFQ3U
350runner
tx
Ceasar
Not an hei but it will give you an idea... How Ignition System Works: http://youtu.be/W94iksaQwUo
350runner
tx
Ceasar
This is what I'm expecting yours to do or not move at all with ease...
Sticky hei distributor: http://youtu.be/QibTSk3BafI
Skweegle89
Oklahoma
85swb "Fancy"
Thanks chief. I will get on that tomorrow and see what I can find.
350runner
tx
Ceasar
Compare the last video to the first video and you'll see what is right and wrong.
350runner
tx
Ceasar
Good deal. Take your time. Fauck it's cold....
350runner
tx
Ceasar
When you get to taking off the cap take off the rotor as well. And perform the 1st and last test. Same thing really. Make sure you hold the rotor still while taking out the two screws.
350runner
tx
Ceasar
In the last vid... at the end notice how he was able to lift the weight up and down wit one finger? Not good. Either the weight, bushing, or shaft the weight sits on is worn badly
Skweegle89
Oklahoma
85swb "Fancy"
10-4. I picked up the fel pro gasket just now. Will swap them out tomorrow and let you know what happens.
Skweegle89
Oklahoma
85swb "Fancy"
Maybe I should have just bought a whole new dizzy while I was there. With my vac advance problems and whatnot. It's a 60 mile round trip to the parts store.
350runner
tx
Ceasar
Re: 85swb "Fancy"
Throw the gasket on after you check out you cp and weights. Since this running rich issue was going on pre q jet I'm willing to put focus on the timing. One thing stock carbs rarely and I mean rarely ever do is foul plugs or even run rich unless the idle screws are outta wack... Unless you run too big of a carb... Heck I run 800c.f.m. q jet from a 454... test the dizzy out first eliminating the possible causes. Trust you hard work will pay off :cool: and you'll be a pro at this carbed engine thingamahbob lol
sam s
