backfire under wide open throttle
Sad Sack
Omaha, NE
Goober
C15
If no spark, remove the dist cap and make sure rotor is turning. Test ignition module at your nearest autoparts store. Rare when coils fail but they do and are fairly cheap so swapping coil out may be something to try. Then dead-time the engine using TDC technique and confirm wires are correct for each cylinder. Report back.
burnt
