SirRobyn0
- Dec 6, 2019
- In the woods in Western Washington
- C20
I would run the new idle mixture settings and see how it does. Outside of that it'll be opening up the carb and looking for issues. I have a sneaking suspician this will help you out at least some, but it'll all be in how it does your next few drives.
You don't absolutely have to have those valve cover things, BTW they are called spreader bars. Some gasket kits will come with new ones so the are not hard to get. The thing is it you don't run the spreader bars, the clamping force will be more in just the spot the bolt is at and it will be easier to split the gasket at that point and or bend the tin valve cover. It's surprisingly easy to bend the factory tin valve covers, and once that happens the gasket will leak like crazy because it won't be holding it down properly anymore and you'll have to take the covers off tp tap the bends back out.
If there is no other hole then the yea you'd have to add oil though whatever holes there are.
