Coolant Hose Popped Off the Thermostat
legozombie
Colorado
A
5.7 350 v8
So I'm here in Colorado and just experienced the winter storm Anya. I'm not too familiar with engine cooling systems so I'm not sure what happened.
I had my truck running with the defroster on full blast while I shoveled snow (so idling for about 15-20 minutes?). I was on my way to drive it around and smelled something funky and saw some smoke behind me as I drove off. Thinking it was just condensation or whatever I went a couple of blocks and noticed smoke coming through the firewall. I pulled over, popped the hood, and noticed that the upper radiator hose was off and everything was covered in green coolant. The hose clamp was tight and the radiator was not compromised. What could have caused the pressure to build up and pop the upper radiator hose off the thermostat?
legozombie
Colorado
A
5.7 350 v8
After installing a tachometer today, I was idling around 200 RPM or so when my truck was idling with the defrost on. Could it be that the water pump wasn't able to move the fluid around at such low RPMs and then caused a pressure build up?
How do I test if my water pump is failing?
I think some coolant may have gotten in my carburetor since I forgot to put back the air cleaner from the last time I touched it. How screwed am I? It still runs and drives.
legozombie
Colorado
A
5.7 350 v8
I'll double check the tachometer to make sure I have the setting for v8 setting.
77Dmax
vt
Joe
I wouldn't over think this one. Replacing radiator hoses used to be very common. I would replace the hose and move on.
legozombie
Colorado
A
5.7 350 v8
I appreciate the advice, I was lucky I pulled off before I left my neighborhood. I refilled the coolant yesterday and it took 2 gallons of coolant 50/50 to fill back up. I still need to take my gauge cluster off and fix my engine temp gauge needle so if it happens again, I can keep a better eye on it. The needle was brittle and fell apart lol. My biggest fear is it happens on the highway and I have to get it towed.
First thing I’d do is to replace the radiator cap. If the pressure release is bad it might let it get too high. I think the stock cap is rated at about 16 lbs pressure for most SBC’s. Also make sure it pushes coolant into the overflow when hot, and then draws it back in as the engine goes cold.
I had challenges finding the correct sending unit for my ‘75 (GM discontinued the original), so I was not positive the gauge reading was always right. I finally added a mechanical temp gauge from Summit and used the threaded hole in the passenger side to install it. It’s a simple way to keep an eye on engine temp.
Keep your heater on and check the temp every now and then,if it gets cooler pull over and check. Keep some 50/50 behind the seat.
Okay this is ghetto but it'll get you by in a pinch. Make a long jumper lead out of speaker wire,connect 1 lead to temp sensor,1 to ground under hood. Route into cab, connect these 2 ends to multi meter leads. Monitor temp sensor resistance. Leave your meter some where easy to reach read and turn on and off.
JBswth
Vallejo, California
James
C25
292 cubic inches
You saw steam, not smoke. Your radiator cap might be frozen, so that the center plunger can't be pushed upward by excess water pressure. Liquid can't compress, so excess volume has to go somewhere. Good think you didn't crack open any part of your radiator.
83 Box
Louisianna
c10 Silverado
What altitude are you at? At altitude, the thinner air will make water boil at a lower temp. A 50/50 mix of water/antifreeze could be affected. The altitude can also make the engine run rich unless adjusted for that altitdude. I have had rich running engines idle at lower rpm.
Good luck with your issue.
legozombie
Colorado
A
5.7 350 v8
At ~6k feet. I replaced the radiator hose and put spring clamps instead of hose clamps. I'm pretty sure the thermostat froze shut but I ended up just avoided driving it in cold weather. So far no issues. I still need to top off the radiator but it drives around well for the most part.
projo198
Lawson MO
James
Because of the low cost I would go ahead and replace the hose, thermostat, coolant and radiator cap.
As for coolant in the carb may be a good idea to run a heat gun or fan down into your intake for a bit to hopefully evaporate any of it out. But if you've been running it since then with no issues it's likely already gone.
JoeyPepperoni
