Convenional vs Synthetic
Conventional or Synthetic
  • Total voters
    32
87scotty
Central il
Andrew
V20
5.7 for now
Id run a name brand castol valvoline ect theres a reason they are where they are thats me though
Iowan
Loud and Proud American!
Iowa
Calvin
K1500
350 crate
Ok.
gmmatt81
Knoxville, TN
Matthew
4.3 L
Conventional with the moly-graphene based Everglide EGC as my oil additive. 2nd bottle now. Very pleased with it. Check out the applications and recommendations on their site. Huge help in fixing my square's overheating and noise issues. Delco for my filters.
75gmck25
Northern Virginia
Bruce
Since most of these older engines have flat tappet cams, the amount of Zinc in your oil is probably more significant than synthetic vs. dino oil. However, I switched to synthetic when I installed a new crate engine, since I don't drive my truck a lot and wanted to extend the oil change intervals.
I have found that Mobil 1 15w50 oil has the high Zinc I want (1300 ppm), and its available at a reasonable price from most parts stores. Many guys run variations of racing oil and diesel engine oil to get high Zinc, but Mobil 1 is frequently on sale, and I can find it easily. Mobil also has a 5W40 diesel truck oil with 1300 ZDDP, if you think you need lighter weight.
I have no affiliation with Mobil, I just happen to buy the product.
Bruce
Shilaeli hugger
Ohio
Burdaddy
V20
In my last 87 that had a 79 350 i ran shell rotella. Think was straight 30. My buddy runs that in his 82 k30 454 for the zinc levels. Its been a few years since ive had that truck. Moms 86 i think i put in rotella last time but not exactly sure. From what ive been told if you look at the alpha numeric coding on the lable i believe the cg4 (i may be wrong) is the one with acceptable levels of zinc for flat tappet. Like i said its been awhile since ive had to mess with em so i may be off a ways.
Iowan
Iowa
Calvin
K1500
350 crate
We have lost of new guys on the forum so I figured I'd bring this back for more opinions. Also when I read through this, I was amazed how far I have came sense then.
Craig 85
Nashville, TN
Craig
K30 SRW
454/TH-400/NP205
I run conventional 10W-30 with a zinc additive from Lucas.
4WDKC
Southern Florida
Kacy
Valvoline VR1 racing 10w30
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
That’s what I was running via a friend for 5 bucks a quart. Bad part bout that is it doesn’t really have the longevity of normal oil. Rotella T5 now.
4WDKC
Southern Florida
Kacy
how many ppm zinc is in that?
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
This is what i use religously and have been for many years in all my vehicles. After all the abuse ive given my burban on hardly any oil changes and its over 300k miles i do believe thats why its gone that far. Plus a can of restore ( when i do change the oil)
74 Shortbed
I second that, been using Castrol since the 70's great stuff..:waytogo:
bedwards
Adger, Al.
Bryan
c10 Silverado
I'm running T5 10w30 in both my square and my f250 diesel. Diesel likes it but the square is using a little and didn't use any on the dino 15w40. Truck is very low mileage so I don't think that is the problem.
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
Can you use diesel oil in a gas engine? Always curious about this....
Donnieboy32
