Center dash speaker options?
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
Big yellow is finally getting a radio soon. It's been a firetruck it's whole life till I got her. I'm putting in a period aera am/fm radio in it. Only planning to hook up to one speaker. The center dash speaker. Looking from underneath there is no speaker up in there.
My questions are. A- How hard is it to install that speaker? B- where should I get one from. I want it to last and sound OK for a single speaker. Thanks in advance for any Intel.
SquareRoot
Installation is easy. Just pull the dash cover off and there's a hole looking for a speaker. My truck didn't have that speaker so there may be a bracket involved that I'm unaware of. First thing to check is if your dash pad has the perforations in it for the sound to come thru?
squaredeal91
Greg bush
1991 SB
Good question root. Just looked and actually have 3 perforated areas.
I might as well get all 3.
SquareRoot
Sweet. I'll make a suggestion based on my experience. Forget the center speaker. It's an oddball size, requires a very small magnet to fit in the factory hole. Suggest getting a pair of 3 or 3-1/2'"coaxial speakers for the corners. MUCH better sound. I have 8 speakers and a sub in my truck and the small ones in the dash make a big difference in bringing the sound stage up and in front of you. I have these Kenwood's and they will drop right in place. Easy Peasy
squaredeal91
Greg bush
1991 SB
Shizer! Thanks @SquareRoot ! I think I'm hooked up! My wife got me these for Christmas for 1983 pre Reagan bumper regal coup fronts. My plans for that care have changed so I probably won't be needing them. Perfect
Craig 85
Nashville, TN
454/TH-400/NP205
Here's the bracket my '85 had a the front dash corners. If you don't have them you may need to fab something. I put my speaker on the under side of the bracket to clear the tweater (yes those screws got trimmed).
squaredeal91
Greg bush
1991 SB
Received my radio yesterday!! Thanks to a Generous member I got hooked up like a tow truck. Going to order and replace all the bulbs in my cluster and make speedometer work.
When I do this.
SierraClassique
Michael
5.0L V8
new to the site and not sure where to post pictures in a place where it would be most helpful for the overall GMSB community, but I installed a retro-modern stereo, four 3.5" speakers across the front dash, two 4"x10" speakers in the back, and a subwoofer under the driver seat earlier this year- happy to share if helpful. good luck!
squaredeal91
Greg bush
1991 SB
Sorry for not updating and completing this little project, I've had other projects take precedence lately. Anyways I removed the diamond plate radio hole cover and I'm pretty sure someone has cut this thing out? Or am I wrong? If it's been cut I'll have to make a plate fit the radio then graft it into my dash.
Bloodhound1981
MA
Rusty
C-10
That's a factory double-din hole which makes sense if your truck is a '91.
wywarner
