Disassemble Clean Roller Lifters, for L31 Vortec SBC
RanchWelder
Earth
Blazer
355ci
Cleaning your roller lifters can go a long way to saving money on a rebuilt Roller Engine.
First carefully remove the clips with a pick or small screw driver.
You can tap the internals out onto a steel or wooden table.
There may be a line of oil residue, that fights the piston and spring from coming out easily. Just be patient and tap repeatedly, but not so hard as to damage anything.
If you get around a minute of steady taps, try using an air compressor and a quality air nozzle to force the piston and spring out, with a blast of air throught the lifter.
Unless there's a bad groove worn into the barrel, they will eventually come out, after you break the hydro-lock from the oil remaining inside the barrel.
Then polish everything with a green or blue scrubber pad.
You'll notice the ridge is now gone.
After re-assembly, the piston will have double the movement of a used lifter.
Look for compressed or broken springs.
Verify the wheel on the rollers has no slop or bearing wear.
More than .004"play, means the bushing or needles are shot.
The rusted or worn outer barrels should be discarded.
Here's a few pictures:
RanchWelder
Earth
Blazer
355ci
When it's time to re-assemble each clean dry piston, spring, plunger and stainless cap, make use of a hex nut driver, so you can squeeze the piston, spring assembly, with a spring clamp.
You might want to have a helper if your clamp does not release easily. It might throw parts around the first few times.
Be prepared to see things go flying, till you get the hang of it.
Once you get full compression, you can carefully insert the spring clip.
I like to use a pick and force the clip into the inner groove, in every direction.
If you have any crud in the groove, your spring will release inside your engine.
Clean the grooves out.
Air pressure is your friend.
You can miss the small stainless pressure baffle, so count all your pieces and make certain every lifter gets the check valve stainless circle.
I tried to reassemble each unit with the same parts that came out, one at a time.
If you see spring wear or a bad piston, you should be able to use parts from another barrel, so long as the unit operates smoothly, after cleaning and rebuild.
Use air burst in the needles, but hold the roller from going high RPM.
The non-oiled bearings should not spin at high speed, without lubrication. Cleaning the needles carefully with air is important.
Clean oil will seep into the fresh lifter needles and pressurize the pistons, during pre-oiling, without getting clogged with a chunk of bearing dirt.
An oil pressure tool, will be handy so the distributor and oil pump can be pressurized before start up.
https://www.amazon.com/dp/B000CP8DKC/
I read the reviews and bought this version.
It required flipping the larger chunk and grinding a chamfer, so it seals better and primes properly.
A lot of the newer versions are sub-standard and do not seal inside the oil galleys.
Make certain your valve covers are off when you prime, so you can verify oil coming out of every push rod on both cylinder heads.
Summit and other websites, do not recommend pre-oiling your rebuilt lifters.
A Hydro-lock can occur inside the pistons, if the oil pressure does not happen naturally from engine rotation and pre-priming.
I'm sure there are guys who have pre-oiled and get away with it, however Summit has documented it would be better off not performed, for best results on hydraulic lifters.
YMMV
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
Great write up!
I went through this when I did the L31 for the Squircle. Getting them apart with the oil varnish groove is a PIA, but they go right back together once it’s cleaned out
RanchWelder
Earth
Blazer
355ci
From what I'm reading on several other forums, cleaning brand new lifters might save your engine.
There's only one way to know if there's any crud or metal bits in new lifters and that is to take every one apart, micro-polish every surface and verify each for smooth function.
Washing the rust inhibitor off new pushrods falls into the same catagory.
It's tedious and slows the install down, however the work put in and the peace of mind.
Knowing "you tried to do the best you can", is worth it.
Somebody standing over the manufacturing line, constantly saying: "We don't have time for that", seems to be the problem with engine failure and the aftermarket parts failures. When you add to it the part time builder mistakes, things can get ugly fast.
Some race car mechanics will suggest using a known good working part, (such as a low mileage OEM needle bearing lifter), over a new bronze bushing version, because it is known OEM hardness with a better bearing.
Lot of lifter failures:
Camshaft:
This is a Flat tappet cam and supposedly high end lifters with less than 2400 miles, three oil changes with zinc additive.
3 lifters were this bad.
There's no way the hardness on these parts was up to standard.
1STLS1
West Phoenix AZ
MIchael
Camshaft:
A long time ago when I rebuilt my first motor and it wiped the cam out, the machine shop explained the issues was the lifters were not spinning in their bores freely enough, not a manufacturing defect. Scotchbrighted the lifter bores, installed new lifters, cam, cleaned everything, reassembled and it stayed together. The lifter face is concave and is designed to spin as it's ramping up. At least this is what they told me.
JoeyPepperoni
