SirRobyn0
- Dec 6, 2019
- In the woods in Western Washington
- C20
Ok so here's the deal. If you know me, you know I like to have a plan in place. With my square it is heavily relied on, as it is the primary hauling and towing vehicle for the farm. I know it's old and one day the tranny will go. Now I've got a plan in place when that time comes. I should have plan in place for if / when the motor goes. Currently it has a healthy 305 under the hood, and even though it's slower than I'd like at times when towing, it still gets the job done, so I'm unlikely to ditch it until it needs a rebuild. but when that happens I'd like to have a plan in place.
I've thought about just rebuilding the 305, which I do like that it'll hit almost 17 on the highway empty if driven at moderate speeds, but that's about it. I've thought about going to a 454 and in some ways I think I'd be best served by a 454 when towing or hauling heavy loads, but it requires a fair bit of work, and will result in 454 gas mileage empty or loaded. I know I've mentioned gas mileage twice now, so go ahead and roll your eyes. I know a square isn't likely to break any MPG records and I'm not looking for it to. But this truck does feed runs for the farm (and other runs) and when on a 100 mile journey one way to get feed and fuel usage is one factor. Ability to pull hills is another factor, as I live in an area with lots of hills, and there are mountain passes to the east and south of me. I don't do the east one often but the southern one quite often, and coming back loaded.
So recently I've been thinking about going the vortec route, when the time comes, whatever I do I'll need to keep it economical in price, and as quick as possible so the truck isn't down for to long. To that end I would be carbureting it. If I could find a good used one at the time I needed it that I thought had a good amount of life left in it I would absolutely go that route, but in all likely hood I'd probably have to buy a pre-built long block motor / crate engine.
What I know:
Will need to buy carb'ed intake manifold
Will need to install electric fuel pump
Can reuse my distributor and carb
What I'd like to know:
Will I be able to reuse my, exhaust manifolds, motor mounts, flexplate and think but do not know that the belt driven accessories, alt, WP, PS ect and brackets bolt up to the vortec (looks like it).
As said before this truck is relied on for 100 mile runs, so this needs to be a set up I can depend on both loaded and empty.
If your running a carb'ed vortec how do you feel about it? Would you do it again? Very open to advice and thoughts on this subject. Thanks.
What I know:
