Chip?
So what all do i need to buy? Gasket Set, .....?
after thinking about it more...
I'm guessing the fuel pump is wired through the harness not straight to a hot.
And is there a way to test the current 87 fuel pump/sending unit? The bed is off the truck so i can easily remove it.
I started labeling and disconnecting the wiring harness today. So far not bad.
Can I jump a little 12v power to a lead to test it?
I hate to be a pain. But which relay is the pump relay? Can I just unplug the harness at the tank and run 12v to one of those pin? Im not referring directly to the sending unit pin, but the 6" long harness attached to the sending unit
Like I said, bed is off it so I can easily just hit the harness at the sending unit. Just need to know which wire is for the pump and which is for the fuel gauge
Hmmmm....lol can u try again.
All you need is the harness from the ecm and the engine...dont need the interior wiring.Well I spent the day pulling wires out of the donor.....what fun that was :/
I left the ecm to engine wires connected for now.
So currently spread across my work bench is all the interior wiring. I started at the ecm wiring harness where it had a 6 pin connector just off the ecm itself. I pulled from there all the way to the instrument cluster then to the fuse block. So I have allllll the wiring. I've got all the tape off now. Is there any write up or info on what I can cut and what I need?
So far my tracing has show me that it goes from the ecm to the vss modular, instrument cluster, obd1 connection, ecm1 fuse, and an orange/black black/white connection at the steering column.
