SquareRoot
- Mar 18, 2017
- Arizona
- Mike
- K20
Shitcan it. LS swap.
Check compression... could be a valve sunk into the head.
Shitcan it. BBC swap.
Replace the fuel filter AND run a bottle of Lucas complete fuel system cleaner in the tank. You might also clean your carb well while you're at it.
Or use Seafoam in the tank
What shape is your distributor cap and rotor? Securely fastened?
whats a cat converter? sounds like a commiefornia government listeneing device.Cat is all packed up with ****!
I bet you can lay on the gas pedal and it sounds like your motor is in a tunnel 10,000 feet down doesn't it?!
Im a cat and i have first hand knowledge it doesnt work.A cat converter turns cats into whatever they wanna be.Kinda like Caitlin Jenner.
for example, i asked for me to have friends and be loved by someone in life.
Told you![]()
