Can't make it up my driveway
MisterB
Northwest
AJ
GMC K2500 4X4
Replace the fuel filter AND run a bottle of Lucas complete fuel system cleaner in the tank. You might also clean your carb well while you're at it.
Sent from my SM-N975U1 using Tapatalk
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
Check compression... could be a valve sunk into the head.
Shitcan it. BBC swap.
Sorry - no real info here, but these **** can its remind me of this.
Limey
Lawrenceville GA
Thanks Mntmankev, i will replace the fuel filter and check the timing this weekend. I will let you'll know of my progress.
Thanks so much for all the advice and tips. I hope to help someone out myself one day.
Red Rex
Middle Ga
K 1500 4 WD shortbed
Or use Seafoam in the tank
What shape is your distributor cap and rotor? Securely fastened?
Cat is all packed up with ****!
I bet you can lay on the gas pedal and it sounds like your motor is in a tunnel 10,000 feet down doesn't it?!
whats a cat converter? sounds like a commiefornia government listeneing device.
A cat converter turns cats into whatever they wanna be.Kinda like Caitlin Jenner.
Im a cat and i have first hand knowledge it doesnt work.
for example, i asked for me to have friends and be loved by someone in life.
Told you :(
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
Told you :(
Damn - how do you type with claws ? :think:
You got friends here, BTW. :)
Also, check your distributor weights. my truck had intermittent behavior such as yours i could never figure out. the weights stuck out and my timiing was retarded heavily. So after cleaning weights, truck actually didnt run right, so i had to advance it and it smoothed way out.
Also fuel filter. i have a lot of junk that gets caught in my filter, from my fuel pump thats breaking down. imagine 10 years of old rubber, debris in tank, bad gas, etc. if you got stock qjet its right there easy to get to.
i would just say inspect your weights for operation before adjusting or checkingtiming, its a 2 min process.
I would also recommend a compression check just to make sure you don't have something mechanical going on. I had an issue with it detonating under load and it turned out to be too far advanced AND I had a valve spring broken
Limey
Lawrenceville GA
Thanks again guys,
Quick follow up, is the fuel filter connected to the carb aka quadrajet? Or attached to the frame close to the gas tanks? My K10 has 2 gas tanks.
Ive not found much info on youtube on changing the fuel filter.
mtnmankev
Ash Fork, Arizona
Kevin
K10, C20
383 Stroker, 350
The Q-jet carb usually has one behind the fitting the gas enters through.
There are two lengths used, short and long, and either paper or bronze.
A lot of people (like myself) add an inline filter by the tank switch solenoid, and sometimes one between the fuel pump and carburetor in the engine compartment.
Limey
Lawrenceville GA
Ok guys, the mystery deepens. I replaced the fuel filter, started her up, made it out of the driveway and up the street. Ran rough, but no stalling under load. Got back and noticed that spark plug #3 was not connected. Bonehead move i know. I had pulled the wire to check the plug (plug was fine btw). So I re connected the wire, and now im back where I was. Cant make it up the street. So in essence, she runs better without #3 connected.
I am waiting for a friends compression gage, to check as many of you pointed out. Does anyone have a diagram of firing order on distributor? 305
jlyon1006
