Big block running hot. Can’t figure out the issue
nvrenuf
Mobile, Al.
Maybe check the radiator real good for flow. Possibly flush it for good measure?
What about belt routing, I've seen serpentine belts that could route differently than intended. Could the belt be driving the water pump in the wrong direction?
It would be a last resort since it would be pretty involved but maybe pull the water pump and compare it with another to verify the pump impeller is correct / reverse rotation?
Slooptin
Denver
Vance
k30
I’m planning on pulling it and taking the cover off to inspect.
Show us some pictures of your set-up. Mainly the serpentine set up.
Once I get home I can snag some pics
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
I'm wondering if it's not the head gaskets covering up a water port? Total shot in the dark but it can happen.
77Dmax
vt
Joe
It's probably not the cause of your ovwrheat issue based on your symptoms, but you should check your total timing and power time it. If you are running stock advance weights and springs you are leaving a lot on the table.
There is no reason to throw head gaskets at it at this point. It passed the coolant test and its not losing any. You'd also have running issues/misfires if you popped a gasket. Any possibility that the coolant is contaminated? I also wonder if the water pump is wrong, maybe boxed wrong? I hate to ask a dumb question, but is the pump spinning backwards? The wp pulley would be run by the smooth side of the belt if it is..
Galane
Idaho
Gregg
Sierra 3500
Did you check the bearing clearance with Plastigage to be sure they weren't too tight?
If there's nothing wrong with the cooling arrangement, a bottle of Redline Water Wetter in the coolant will help keep the temp from getting so high. Another thing to try is a special engine break in oil additive with molybdenum disulfide.
I'd still turn the crank pulley and see which way the waterpump turns. Can't get it straight in my head if an incorrectly routed belt could have the pump turning the wrong way
77Dmax
vt
Joe
I'd still turn the crank pulley and see which way the waterpump turns. Can't get it straight on my head if an incorrectly routed belt could have the pump turning the wrong way
In a serp setup any pulley that is turned by the smooth side of the belt is spinning opposite of the crank, any pulley that is spun by the ribbed side turns with the crank. Nearly all serp setups spin the water pump reverse beacuse the belt goes between the crank and water pump in an "S" route to maximize belt contact to the crank pulley. That "S" route spins the water pump backwards. " V-belts have all the pulleys spinning the same direction. So its more of a problem of swapping pulleys or pumps and putting the wrong pump on.
I learned this lesson 25ish years ago swapping a 2.8 from a camaro into an s10 blazer. The camaro had V belts and the blazer had a serpentine setup. Naturally I put the serp brackets on the camaro motor. That 2.8 ran perfectly cool in the camaro but ran hot in the blazer for seemingly no reason. Eventually I was made aware of the pump rotating backwards with the serp setup swap. I put the proper pump on and all was well again.
Oh I know the theory and how it is factory. Where I question it is if someone really strayed from factory routing,I can't convince myself that there isn't someway to route it wrong and end up with the smooth part of the belt turning the pulley the wrong way. I have this same problem in my mind with other things. How do we know in just 1 oddball situation things won't go in a direction we don't think they should. I over analyze a lot and still double check.
77Dmax
vt
Joe
I gotcha. They would have to put the ribbed side to a smooth pulley or vice versa, and that would be hard not to notice. Its a convoluted routing, but either the pulleys are on the inside of the belt or outside
MXer908
