Big block chevy build, 489 stroker
kellerbm
US
Brandon
427 tall deck
Been a while sense I posted anything about my 427 tall deck engine block, just want to share some pictures with every one on the progress.
Sent from my SM-T710 using Tapatalk
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Nice!!!!
da_raabi
Trailer Park Supervisor
FloriDUH
Adam
c30
Wow. Very cool. I see you went with domed pistons. What kind of heads/CR are you looking for?
Also, since you went that far, why not go all the way to the 496?
kellerbm
US
Brandon
427 tall deck
11:1 compression, edelbrock performer rpm 110cc heads with a 290cc intake. Didn't bore block to a 496 because I didn't want to waste the engine block if something happened and not much more of gain.
kellerbm
US
Brandon
427 tall deck
I'm putting together the cylinder heads soon, have everything needed. Still have to check piston to valve clearance because pistons are domed. Then i should be able to measure push rod length for my full roller rockers. I will keep posting pictures as I continue.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Cool. Get your self a set of dummy valve springs
kellerbm
US
Brandon
427 tall deck
Nah, going to use a sharpie and a push rod length checker..
kellerbm
US
Brandon
427 tall deck
That is very nice. That's one of the few big blocks I would change over for.
Will be nice, but i have a feeling I will be replacing some u joints and the gear and pinion when I get it in the truck.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Thank you, I do have one, but I think you meant to quote Brandon. Lol maybe not.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Ok, I usually use dummy’s and a dial indicator, then again you kinda need push rods too.
animal
Lee
c10 silverado
350ish
Nope Quoted your "NICE" post. Someone local to me has 2 as a pair on CL. A I think 67 and 68. Wants 12K for the pair. That's just the one BB that I always wanted.
kellerbm
US
Brandon
427 tall deck
Was going to use play doe to check the piston the valve clearance, flattening the play doe to like a 1/4 inch and lay on the piston. Then set the cylinder head on and snug up the head bolts and turn the crank over. Pull the head off and measure the indentation of the play doe with a micrometer to figure gasket thickness.
jimlayhee
