Big block chevy build, 489 stroker
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
In my opinion I don't think you would get much more of a gain from a 496 compared to a 489. To many variables on what you want out of the engine. Style of piston can change the compression ratio as well as rod length.
Sent from my SM-T710 using Tapatalk
It sounds cooler, but not as cool as 505. Lol
kellerbm
US
Brandon
427 tall deck
Gotchya mine is an 86 I’m planning 4.5” stroke when I do mine.
Hope you got some money stashed away haha
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
I have a friend that’s a machinist. It’s all good. I can do the clearancing myself
kellerbm
US
Brandon
427 tall deck
Probably right, but when you get that far I want you to tell me how much you enjoy putting gas in the old girl..
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
My set up now is mix of 93 and 110 and that only a 407
kellerbm
US
Brandon
427 tall deck
Most tall decks you can safely go .100
I wouldn't agree 100% with that only because of how close you are to the water jackets. That and how steel shrinks and expands do to heat and cooling could do some serious damage to the rings and pistons over time... just my opinion though.
kellerbm
US
Brandon
427 tall deck
400 big block bored .030 over, what are you running flat, dished, or domed pistons
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
.030 402 with domed pistons and 97 cc chambered heads and a **** load of timing
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Tall decks have thicker walls and decks then standard big blocks
kellerbm
US
Brandon
427 tall deck
Nice, what size carb you running?
kellerbm
US
Brandon
427 tall deck
I don't think so, same lay out as a standard just different deck heights. The tall deck is .400 higher than the standard which you have to use longer connecting rods which gives you more stroke then a standard deck.
kellerbm
US
Brandon
427 tall deck
750 with an HP main body
That would be the ideal size I was going to run with 750cfm Holley
kellerbm
US
Brandon
427 tall deck
2 bolt mains are recommended .060 over standard bore size, 4 bolt mains can be honed .125 over standard bore size.. but isn't recommended do to risk of engine damage.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
in the bbc world the low deck is 9.8 from centerline of crank to deck surface, tall deck is 10.2 crank to deck height. Also have .400 longer rods and pushrods. WHY? monster torque builder. We built a 505 bbc using a 427 tall block, with .100 over bore and .250 stroker crank. The lower end of the water jackets were grouted to stiffen them. Used for super/gas super/comp car. Peak Hp of 812 was in under 6200 rpm, really close to the launch and shift points. I copied it not my writing
vkh
Western Montana
Var
C2500
I thought factory talldeck motors used the extra space for a taller piston with an extra ring. I was under the impression the connecting rods were the same length as a short deck motor
ben_swager
