Battery posts corrosion wtf
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
I've had the truck 4 or 5 years now and no corrosion on the posts at ALL. Now all of a sudden I'm getting it. Wtf?
I cleaned them about a month ago and now the negative post is fcked again. I don't get it. I cleaned and greased them last time and here we are. Any suggestions will be appreciated.
The ground to the block is clean. :mad3:
82sbshortbed
Fuckemall!!
SE Texas
Doug
It is 4 years old at least
Soundmound
North Central Washington
Dave
Scottsdale
Yup verge of replacement. Bet when the weather turns cold it goes belly up on you. I always lose my battery around 4 years and when the seasons switch from hot to cold or cold to hot.
Auburn, Washington
I’ve had luck (temporary) with re-sealing around the bottom of the battery posts with rtv.
1STLS1
West Phoenix AZ
MIchael
This is the truth, the change in weather is what takes them out.
fast 99
Spokane, Washington
Exactly. ran a towing service. Any weather change we got busy. Hot to cold, cold to hot, dry to wet, or wet to dry didn't matter. Got totally inundated when below 0. Those 4-year-old batteries wouldn't cut it.
Albrigap
South Dakota
Alan
Suburban
I have an 82 6.2 diesel with 250,000 miles and the cables are like new.
The glow plug controller is also the original.
I only ran Delco batteries and none ever leaked or left me stranded.
Low voltage kills electronics.
Terry Wilkerson
Kansas
Terry
GMC 1500
What causes the + terminal to turn black?
82sbshortbed
Fuckemall!!
SE Texas
Doug
Threw some rtv on the negative post and greased her up again. Seems to hold till I get a new one.
jlyon1006
