- Nov 8, 2023
- Kalispell, Montana
- Larry
- C10
- 250 6 cylinder
Finished everything a few days ago, just need to see what voltage readings I get at the starter terminal when cranking with one battery and then two batteries. From the sounds of the starter turning, it is a higher rpm. I wired the batteries is parallel like the diesel engine set up.
The drivers side battery tray with everything needed was $75 from LMC. Easy bolt in, just had to drill two holes where the wheel well was pre dimpled.
Nice snug fit for a group 24 battery that I already had for a previous vehicle.
I had custom battery cables made from the place in Louisville Kentucky. $80 total shipped, and all my measurements were accurate enough. I upsized the negative cables to #2 awg. Both side headlight ground wires went to a 5/16" screw on the radiator support panel. I was able to clean all the connections and put in 5/16" all thread to make a nice connection stud for everything:
The new battery also has a cable that goes from the ground stud to the power steering bracket:
The positive wire is #2 awg with positive top post clamps on each end and was wrapped in flexible sleeving:
I followed the path of the existing headlight wiring over the top of the radiator shroud. Easy to secure with clamps and zip ties. Since my passenger side battery has both top and side posts, it makes a great junction block for the positive cable. I covered all terminals with protector boots and cleaned the starter connections and firewall junction block:
I am still going to install a ground strap from the engine to the frame and some warning labels. Next project is louder horns and the wipers not parking when turned off.
