Anyone Ever heard of Electrolysis ???
Swims350
Logan WV
none
nice port job lol.
Damn, that's rough lookin man. :sad72:
nice port job lol.
Yeah, I think I'm junkin that head. I know it would probably work since its just exhaust ports eatin away by the rust, but I think its a sign that could be other damage in the head. Like how thin are the water jackets? And probably just take 1 minor overheat and crack !!! I intended on spending to much money on these heads to take that risk. As said above, I have 2 more sets of Olds BB heads, 1 of them being the E heads and they breathe almost as well as the C heads, but have 3cc smaller combustion chambers, giving a tad highter compression ratio.
Yup, just what I was think'n. It would crack or warp easily. Good choice. :handshake:
SlickGTP
Houston, TX
Wowzers!!! Just got through the entire thread... Great job there HRP... I may have to try this one day... :)
Anyone else had any luck with one of these projects???
Swims350
Logan WV
none
I'm actually thinking about doing this to your 2 bbl when I get it from ya.
You might be surprised find NO CARB when you're done. :rofl: I hear this process will melt aluminum.
Driver4r
Nebraska
Trevor
k10,c20
Swims, Just get a gallon of INDUSRIAL Carb cleaner, not the store bought pos stuff, im talking the stuff you should be affraid to touch to much, and throw it in there.
Swims350
Logan WV
none
will it eat rust or crap off the carb itself? since it's oxidized badly?
I thought of soaking it in some apple cidar vinegar and see what happens.
I forgot about it melting alum. though, that would suck lol.
farmerchris
southeast kansas
chris
you can use Drano crystals as a electrolysis medium, Warning potently toxic outgasing but will cut grease buildup and speed up the electrolysis process supposedly.
I've actually thought of doing Electrolysis on these Poor Man Valve Job heads. They're not rusty, but hoping the Electro will remove all the grease and grime, and it will in fact help remove rust deposits from the cooling passages. Might be worth a shot. I'll use the Arm & Hammer washing powder though. I finally found some at one of our local mom and pop grocery stores.
77 K20
Montana
K20 5" lift
HT383 fuel injected
Now if I can only find a tub large enough to drive my whole truck in and do this process...
:D:shrug:
Pretty amazing though, that's for sure.
I was told there is a company in OK somewhere that does it, or used to do it. Buy they did complete frame and body seperate cuz the sheetmetal has to be done different.
1low4x4
Nick
Read the first page. Very impressed with how that came out. Did a great job.
Domarinolo
