Air Compressor Time
OkieFishMan
Certified Camping and Fishing Nut
Enid, OK
OkieFishMan
GMC C2500
454/SM465
A good bit I have an 80 gallon tank on my compressor . I have an Esab 1125 it will sever an 1 1/8” way bigger then I will ever need but the price was right, work was gonna throw it out lol 9 bucks for a few MOVs and I was burning steel lol
Hell yeah! Can't beat a deal like that. I have no idea how much plasma cutters use. I just know that my media blaster uses 12 cfm @ 90psi and the compressor cycles off and on even when running the blaster nonstop for 15 minutes. Quincy makes a hell of a compressor in my opinion.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Thanks everyone. I think it should do me for the rest of my life. If not it can be fixed, it's not the kind you just get rid of and go buy another. I have one more question. Should I hard wire it to my breaker box, or get a plug box, and wire it that way.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
I’d hard wire with a fused disconnect between it and your panel. That’s what I did with mine again just my .02 if **** goes wrong better to blow some fuses then burn your garage down.
OkieFishMan
Enid, OK
OkieFishMan
GMC C2500
454/SM465
I put a plug on mine and installed an outlet in my wall. I thought in the future I may need to plug something else in. I believe I used a 40 amp breaker.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
The Quincy is rated 15.2 cfm @ 175psi and yours is 17.5 cfm @ 175psi. So they are in the same ballpark.
Yup like I said before I was curious I wasn’t picking on them I know they are a quality unit.
I just wired mine right to the breaker box. I leave power to it all the time unless I'm out of town, then I just flip the breaker off.
I also used a 30 amp breaker because that's what I had already. A 40 would be better, but it's never tripped the breaker yet.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
The bad part about that is every time you flip the breaker it gets weaker but it don’t appear your ever home so it sits in the relaxed position
Lol, yeah it doesn't get switched often. Although thinking about it now, I could just flip the little switch on the compressor's box doohickey. Durr.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
I took an old crane down so I re tasked one of its disconnects for mine over kill but I always manage to pinch my finger on the doo hickey switch lol
LDO
MS
Bob
Hey folks, how happy are you with that Quincy from lowes? I was told to go for the 7.5 HP but it is so much more out of my budget that I was considering the 5HP.
My primary use will be to paint with it and run grinders, etc...
I was also looking at the I.R. at Tractor Supply 80 gal tank. I've read that there is a difference in quality between the 5HP and 7.5 HP with these as well....
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
I've been extremely happy with my 5HP Quincy. Even while sandblasting, which is basically a giant air leak, it will cycle the compressor off because it stills builds up pressure. I haven't found anything it can't run yet. Wide open die grinder, impact, painting, sandblaster, it's handled it all perfectly.
Same here. Nevermind that the higher price unit was out of the budget, anything more than the 5hp Quincy would have been downright overkill.
GorillaHumper
