Adjusting valves....
nxtlevl
Hutchinson,KS
Ed
While motor is running, back off the rocker arm nut until the lifter starts ticking...then tighten to stop the ticking..then tighten (?) turns after......I can't remember if it's 1/2 turn, or a full turn.....Was going to play around this weekend and see if that eliminates the annoying ticking noise this POS has acquired....After doing this, am I correct in assuming that if the ticking returns after I've tightened the rocker arms up, that I have a faulty lifter? It's been way too long since I've messed with this crap......:roflbow:
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
K-10
350/SM465/NP205
I like to adjust them with the engine not running, less messy that way. Make sure both valves are closed, and tighten them down 3/4 turn past zero lash, for hydraulic lifters. For rollers and solids, you should refer to the manufacturer for the proper lash clearance but it's usually 1-2 thousandths of an inch.
Swims350
Logan WV
none
I do mine with the motor off and it never works out right. I always have to go back and redo them. One of them on my 88 was too tight. I do them over and over when it aint running, and make sure it's the zero lash I'm feeling, just doesn't work out perfectly. it's close enough to get it going, we run my 88 that way for about a year.
I went 1/2 turn on mine to stop clicking but seems to need more, gonna do 3.4 because I think 1 turn is a bit much.
My old man says you go down like a turn and it'll bog down, wait about 30 secs and it'll come back up to a faster idle and be good to go, if not then you back it off some. I never done that or tried it though.
nxtlevl
Hutchinson,KS
Ed
I know that we use to go in 1/4 turn increments to give the lifter a chance to load up, but I couldn't remember what the total number of turns was needed after the ticking noise is gone....I'll try it out this weekend if it stays decent outside...I'll try it with the motor off, and if that doesn't work then I'll do it with the motor running......if I can't get it dialed in, I'll take it to somebody that has a heated shop....:)
:popcorn:
Irishman999
Safford Arizona
Jason
K-1500 High Sierra
I tightened my rockers until the pushrod would BARELY move up and down, then went a little over 1/2 turn. That was just to get it close, it ran fine so I never finished the right way.
Find some of those clips that go on your rockers to keep oil from squirting everywhere, or dont. Start your truck, run down the nut slowly until you hear the cylinder go dead and back it off until it smoothes out and that should be perfect.
:popcorn:
I tighten my rockers with a screwdriver so they don't squeak as I'm carving wood on my porch as I chew on my tobacky....
:popcorn:
Wacky tobbacky.:baby:
jake wells
Can i be me?
Brownsville Kentucky
jake
custom deluxe 10
Copenhagen snuff and working on a truck is heaven till you choke on your spit laying on the concrete.
I have to stick a straw in my beer when I'm under the Burb. :High 5:
Irishman999
Safford Arizona
Jason
K-1500 High Sierra
Dude you solved a huge problem of mine, I always had to drink the beer before I went under the truck. Now I can do it DURING my time under the truck.
Surely you can rig up some kind of spill proof helmet with straws so that you can drink and wrench at the same time :)
They sell those hiking/biking drink bladders you can wear like a backpack.:roflbow:
85k10383
Glengary, WV
Ross
K10 Scottsdale
Only trouble with a Camelbak is that the beer very quickly gets warm. And anybody who has had warm PBR can tell you, that ain't no way to treat a beer. Now chewing tobacco flavored beer, there would be a good idea..... Have we wandered far enough afield yet?
crazy4offroad
K-10
350/SM465/NP205
We used to put a case of Beast in the creek to keep it cool, but it wasnt near cool enough for most people's taste. So warm beer dont bother me too much. Beer flavored tobacco, sounds like a good idea!!!
Obullard74
