Ac Delco ignition module not compatable wIth duralast distributor?
Hugomartin
Banned
Nc
Hugo
V20 3/4 ton 5.7 350 suburban
make sure you have the right chart for your engine.
also, I'd be sure to trace all the plug wires to make sure that they are all in the correct spot and order on the cap.
I noticed that today my battery is only 12.1 volts. That was unexpected my battery is maybe 2 years old, I haven’t left any lights on but I call this situation a voodoo
gmbellew
Kansas city
glen
suburban 1500
seems reasonable if the engine isn't running.
SirRobyn0
12.1 volts is fine for a non-running engine especially if you have cranked it a few times.
When I was getting into mechanics and older guy at the shop I worked for at the time drummed this into my head for a no start.
An engine needs 3 things to run:
Air
Spark
Fuel
And it needs the right amount of each and at close to the right time.
We can assume it's got air since we are all still breathing.
So that leaves us with fuel and spark. You have already stated it has orange / yellowish spark not blue. That's an issue, is it bad enough to make it not start, maybe, my experience says yes it will prevent it from starting, but I'm also not there watching you perform the test so some variance in what you are doing during the test could change the results.
I'd suggest following a troubleshooting guide is a good idea, but also have this to share. Take the air cleaner totally off the engine. Hook your timing light up to the engine, and have a buddy crank the engine over while you are pointing the timing light into the throttle body just below the injector. If you are getting gas the pulses from timing light make it clear as day and you'll be able to see the fuel spray as plain as day.
Pull a plug out and see if it's wet and smells gas.
If yes you need to do something about that weak spark. If no shoot a little starting fluid in her and crank the engine. If your not getting gas it'll likely fire up briefly and then stall.
Hopefully something there is useful for you.
Hugomartin
Banned
Nc
Hugo
So 12.1v on my battery isnt enough juice to start the truck?
Hugomartin
Banned
Nc
Hugo
Nobody said that, 12.1 for a reading with the engine off is fine. You need to move forward with troubleshooting to find the issue.
I thought I needed 12.4 at least to start? So my truck should start at 12.1v if all things are correct? Thanks
SirRobyn0
These old trucks are not that sensitive. If there is enough voltage to crank it over, it's likely to be able to fire. It is a 12 volt battery after all so when the alternator is not turning and it's sat for a while it's gonna get down close to 12 volts. your welcome.
Hugomartin
Banned
Nc
Hugo
I pulled all the plugs cylinder 6 , 4 looked to be coverd in oil
Cylinder 3 had some build up of carbon. The rest looked good. Do i need a ring job?
Hugomartin
Banned
Nc
Hugo
What’s y’all’s take oil fouled?
zapattack
