A/C Switch
Read
Phoenix
Brandon
I recently purchased 85 c10 and there is a toggle switch below the driver side dash that was added. I followed the wires and they run to a/c compressor and wiring to evap case. Any idea why this was added? Possibly an a/c switch went bad. I flip switch with fan running and a/c compressor kicks on.
I assume that I have to toggle switch off if I want to run the heat??
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
It sounds like a crappy way to bypass the low pressure cutout switch.
yevgenievich
Place
Name
Year
Model
Size
Might be just stock controls failed. Essentially same if it is running through the low pressure switch
The other possibility is some type of bypass or manual on switch for the A/C compressor on/off. The compressor comes on in Defrost, A/C and usually a couple other positions whenever the fan is on. If they wanted manual control of the A/C they may have added a switch. For example, sometimes folks don't want the A/C on when its defrost.
Read
Phoenix
Brandon
Anything I should be concerned with? Is it ok to leave as is?
Crispy
Carbon County, Pennsyltucky
Suburban V1500
I wouldn't be worried unless you want it to operate like stock. Just check for a sturdy connection.
350 w/203
When you want to romp on it but not have to go thru the whole a/c control thing. Kill the compressor.
78silverado
