- Dec 7, 2010
- Southeast PA
- Paw Paw
- Chevrolet Tahoe LT
- 5.3, 4WD
Ok, good deal. Wish I had more to offer. Still thinking.
Is it pus single that the ignition is being advanced so far that it fires to the wrong cylinder and stumbles then goes back to 0* and restarts the cycle.
If i read correctly, Autozone wanted $150 for a fuel pressure "tester"? C'mon it's a damn gauge.
You can put one together a LOT cheaper than that with a couple fittings and a small gauge. Leave it installed under the hood and be able to check your pressure anytime without connecting and disconnecting gas lines (or maybe I'm the only one who gets sprayed 50% of the time).
If you have done this and do a write up explaining how to do it and what exactly is needed to do this and where to get the parts and what the parts names and numbers are it would be greatly appreciated.
Kinda what I was pondering...ign advance so far, that 8 is being fired in 1's place. I was under the impression that you didnt have a timing pointer for some reason. Thats why I suggested retarding it to see if it gets better. The only way you can really be sure, is pull the power to the coil, pull the # 1 plug again, stick your pinky inthe hole, and have it cranked until your finger gets blown out, then see where the dist rotor is pointing. if you do have a pointer(scale) set the mark to 0* by hand, and the rotor should point at the 1 position. Mark # 1 down on the dist body for reference.
I just relized that even if i restab the distributor it will still be timed to 0* and still be advanced too far.
Should it be advancing the timing at idle?
ok thats about what it is doing. when i tried to retard it while it was running it just died.
