1987 TBI Misfiring
rys272
saskatchewan
rylan
wrangler / sierra classic
Ok so this all starts if my memory is correct after I changed my water pump and as I was doing that I was like gonna take this air/smog pump off might as well, if I remember correctly it never misfired before that.
Now the misfiring is absolutely random it’s not consistent it happens in park idling, neutral, driving, it’s consistent in a way that when you hit the gas it starts to misfire a solid amount. so is timing not advancing?
I’ve fixed any broken vacuum lines and have purposely plugged off any that haven’t made a difference because it still misfires.
Rebuilt entire throttlebody down to new screws and cleaned the **** out of it new injectors too they spray/mist perfect
Started with the basics -
Cap
Rotor
Wires
Plugs
Fuel filter
Paper cliped the obd1 32 and 33 came up so I took that vacuum line off the EGR and plugged it, unhooked battery for 30min to let those codes **** off.
Anyone have a similar problem before because my next step is dumping more money
all the last things I can think of -
IAC
Map
TPS
Check every ground over (again)
o2 sensor
Check plugs & wires (again)
Random thing I should mention exhaust is cut off because if i didn’t cut it off it would probably fall off while driving it was that ****** but other than that only big modification I’ve done (No I didn’t cut out part of manifold o2 sensor is still intact and everything)
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
HAve you replaced the EGR? It has a rubber diaphragm in it that can crack/break and leak
Or, there might be a carbon deposit in the pintle. Check that.
Use a mighty vac on the egr, see if it pulls a vacuum.
Code 33... the map
It needs that to be in working order to deliver fuel properly.
TEst it, or replace it
fast 99
Spokane, Washington
Check for steady vacuum then compression after EGR as suggested.
Most times the pintle in EGR can be raised with a finger. If no change EGR is leaking.
Uneven vacuum suggests an internal engine malfunction.
rys272
saskatchewan
rylan
Update, Success kinda? Replaced MAP, cleaned out tps plugin, cleaned some grounds up, Didn’t work had new codes popping up and still misfiring. So it started to get dark out and I was still ****** around with it unplugging tps map etc and all of a sudden I see #5 spark plug arcing like a ************ so I grab one of those old spark plugs what do ya know runs ****** amazing anyways so I’m driving her around for a hour and a half stop home real quick jump back in her take off and half way down the street all of a sudden a horrible bog/misfire like it’s running on two cylinders almost about to blowup so I absolutely limp it home won’t go faster than 5 kmph so yet again I’m stumped did I burn a valve or what gonna pull all plugs tommorow and check them all but really hoping it’s that #5 or some codes popped up.
rys272
saskatchewan
rylan
Been messing around with her this morning right injector good spray working good, left injector absolutely zero spray and then drips once the truck dies, Guessing I got sold a ****** injector?
Vbb199
Salisbury NC
Vince
How about the egr
sherrodmachine
