77 K10 LS Swap
Madhorn
AR-Arkansas
Ken
5.3/NV4500/NP205/4:56 gear/35in tires
Latest donor vehicle. 2004 Tahoe with a good 5.3, 4L60 and transfercase. Approximately 170k miles.
Madhorn
AR-Arkansas
Ken
Latest donor engine and trans pulled from the Tahoe.
Madhorn
AR-Arkansas
Ken
The right rear brake light and right turn signal quit working last Saturday. I figured it was just a bulb, but a new bulb did not fix the problem. After some troubleshooting I figured out that the turn signal switch in the steering column was the problem.
78C10BigTen
pennsylvannia
C10 BIG TEN
That sucks. Theyre no fun ta fix!
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
Sure is a bit of work to get into there, dang. On the bright side you have a tachometer! And I like the wood grain too.
Madhorn
AR-Arkansas
Ken
Alternator went out Thursday on my way home from work. Luckily I made it home without issue. Installed an alternator from my parts pile. Back up and running.
Madhorn
AR-Arkansas
Ken
After a 200 mile duck hunting trip today, the 77 rolled over 60k miles since the LS swap.
I have throughly enjoyed every mile and would definitely do it again.
Camar068
10 yrs Air Force
Glad ur enjoying yours as well I am mine. I can play with more for less mpg's.
kobedemello
