77 K10 LS Swap
Nicholson72
Ca
Ls 5.3
O2 sensors can be a pain in the ass, I’ve had one throw a code every couple days then wouldn’t do it for a few months and then start doing it again and it’s been like 2 years since it threw a code for it lol
Madhorn
AR-Arkansas
Ken
5.3/NV4500/NP205/4:56 gear/35in tires
A small Saturday project. 6x9 cab corner speaker mounts.
Madhorn
AR-Arkansas
Ken
Sounds great. With a 6x9 in each door and now one in each cab corner.
Camar068
10 yrs Air Force
nice cut. As long as it's good to your ear, your good to go.
Madhorn
AR-Arkansas
Ken
Next project is to replace the tube/pipe cross member spacers with 1 3/4 square tube.
Madhorn
AR-Arkansas
Ken
Had time today to get the cross member spacers installed.
Nicholson72
Ca
Ls 5.3
That looks good, I was thinking about doing that to mine to, the small spacers kinda messed up the frame
Madhorn
AR-Arkansas
Ken
Front mud flaps was this weekends project.
Madhorn
AR-Arkansas
Ken
I have been researching AC components for a couple of months now. Found a shop willing to do the custom AC work and I worked closely with their tech making sure I order the correct parts. This morning I pulled the trigger on ordering parts. Vintage Air condenser kit, Vintage Air hose kit, ICT compressor bracket and compressor. Summit had everything I needed. Parts will be here this week. Once here I will get most the nut and bolt installation complete before taking it in to be completed.
Nicholson72
Ca
Ls 5.3
Nice how much you got in parts so far?
roundhouse
atlanta ga
justin
77,78,79,80 ?
I spent about $1600 for the VA from Rutters rod shop in NC
Then had to buy the LS bracket that moves the Comp up top of the engine from some other place
Think it was $160
Madhorn
AR-Arkansas
Ken
So far about $800 in parts. Got started on the install this afternoon.
eskimomann209
Modesto
Marcus
I’m jelly
I want the nv4500 in my SAS 98 c1500
I’m building an LS 383 stroker for it now
eskimomann209
Modesto
Marcus
What was that little box below the wiper motor?
Madhorn
AR-Arkansas
Ken
Part of the drive by wire throttle control. Throttle Control Actuator.
GorillaHumper
