73/78 c10
eskimomann209
Modesto
Marcus
Ok so I’m alright with that was there any reason to run the gasket?
You think that was shim too or for vibrations?
I'd guess it was just used as a shim.
eskimomann209
Modesto
Marcus
Awesome
I figured as much but haven’t pulled off enough of these cans to know
Thank you very much!
Onward!
eskimomann209
Modesto
Marcus
Is this something that changes in thread/ pitch from 73 to 78?
The nuts the hold the steering column up
eskimomann209
Modesto
Marcus
Looks like the 78 might be metric?
eskimomann209
Modesto
Marcus
Pick n jerk scores
Should I grab the kick panel covers?
I grabbed the core support
Light harness (mines been cut and I have a short somewhere
Horns
All interior headliner trim
No headliner
350 w/203
Can anyone tell me about these steel plates?
Do I need these? Only had two
And the weird gasket between the cab and the plates?
Probably ran out of metal shims or tried to get rid of a squeak.
Nice score at the boneyard!
eskimomann209
Modesto
Marcus
Is this plastic thing something for the intake?
Also this is my painting tree
I figured it needed some recognition
eskimomann209
Modesto
Marcus
Lol, I like the painting tree.
The plastic thing is a deflector to keep water and stuff out of the intake tube.
Ahh ok thanks
I guess seeing as how I have an LS engine I could remove that from the core support
eskimomann209
Modesto
Marcus
Does the 81+ battery tray bolt up to the 80- trucks?
eskimomann209
Modesto
Marcus
Wire wheeled the frame painted it some gloss black
Replaced the core support from a 78
Got the horns off it too since mine were missing
New poly body mount bushings
Some
New grade 8 mounting bolts too
Starting to look a little better
78silverado
