73/78 c10
legopnuematic
Licensed Junk Dealer
MO
Spencer
Personally I would cut the part above the heater box how I did, all i used was a piece of 1.5" schedule 40 pvc pipe to form it. For the area behind the engine I would first try to spot blast it or some type of rust remover, if holes start to show then replace, if it seems to remain intact then clean good and coat with some type of covering to protect it and make the piece in front of it.
If you do need to replace-
I would cut the bad out and make smaller pieces as opposed to one big piece as it appears you only have 2 major spots. Get yourself a sand bag and some rubber, wood mallets, or plastic hammers and experiment with making curved pieces
eskimomann209
Modesto
Marcus
@legopnuematic
Yeah I have the heater box section
That was for converting to heat only then the cowl area almost all the way across to the other side of the engine..
But there’s putting all along the “seam”
I was trying to make cuts that I could form in sections.
I was planning on trying to use rust converter but I’ll cut it out and form new steel.
Thanks Partna
I weld thicker steel and not the sheet metal crap
But welding is welding I’ll get it done
eskimomann209
Modesto
Marcus
Also none of it made it through
I can see the backside it all looks good
I have the metal dash removed
eskimomann209
Modesto
Marcus
Can anyone guess why?
eskimomann209
Modesto
Marcus
Ewww
Light sand and primer on the way
eskimomann209
Modesto
Marcus
To get this back on track here is an exterior pic
eskimomann209
Modesto
Marcus
That grey square is sexy!!!!
Haha that’s the doner cab
She’ll be moss green here soon
Internet magic
She’s wire wheeled and the inside is coated in primer/ gloss black
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
Internet magic
How much of that cab is being donated???? Just the bones or......?
eskimomann209
Modesto
Marcus
green cab has rust on the
Cowl
Floor
Rockers
Back wall
Roof
All around the windshield
Etc
Donor is a 78 firewall had a little rust
While I was fixing that I decided to smooth it out
Green truck also needed a pass fender and inner
So I grabbed a “repo” one
I don’t recommend them in the future
They’re a lot thinner butnitnlines up ok
The donor cab had a banged up metal dash cage so I cut the one out of my green truck to transfer into the new cab
luis1jr
