427 tall deck motor swap
puke171
Kansas
Wes
427 Tall Deck
I found a good deal on a 427 tall deck out of a 83 c70 feed mixing truck a few months back for my 79 K25. I bought a stock rebuild kit from northern. I also got a cam form comp cams. It had a set of 772 heads on it, and a governed holley carb that has to go. My question is are the heads worth having rebuilt and have bigger valves in, or should I get a set of 781 heads. The truck is my cutting truck for fire wood and is used to pull a stock trailer. Also the front u motor mount bracket is broken does anyone know where to fine one besides a junk yard.
COMP Cams 249-11-235-3
Intake Valve Lift (in.)
0.505
Exhaust Valve Lift (in.)
0.515
RPM Range
1000-5400
Int. Duration @ .050 in. (Deg)
218
Exh. Duration @ .050 in. (Deg)
226
Int. Duration Advertised (Deg)
262
Exh. Duration Advertised (Deg)
270
Engine Make/Size
Chevy Big Block (396-454)
Lifter Type
Hydraulic Flat Tappet
Usage
Street/Performance
The front motor mount bracket from the C70 is broken? Don't worry about it, your truck doesn't use that bracket. The 427 will bolt up to stock V8 pickup mounts.
anubisani
MIAMI, FLORIDA
SEAN
R/V 3500
454 TBI TH400 4:11 gears
343772.....68-86...oval...OPEN...366T, 427T, 454
336781.....73-85...oval...OPEN...454, 118cc chamber, 256/114cc ports
the 781 heads are supposed to be better, heads we used them for racing.
puke171
Kansas
Wes
427 Tall Deck
This is just a random picture off to be the internet so you can see what I am talking about. The red line is where it is broken. I will get an actual pictures on friday. But a standard 454 bracket should work?
I know the 781 heads are supposed better but I am on a budget and it is not a hot rod. I am just wondering how 772 heads compare if you take out the small valves and have the standard valves put in. Im not to cheap to buy the better heads if it will help alot. But im not going to spend a few hundred dollars on 10 horsepower for a truck that will be covered in cow crap it's whole life.
68post
Indianapolis
Tim
454, TBD
For the rpm range your cam is and staying at 427 ci - I'd use the existing peanut port heads and don't worry about it. Same for the larger valves too, but get a valve job if the heads are off.
$.02
That bracket is only used to mount the engines in the C50-C70 trucks. Half tons through one tons use the regular mounts that bolt to the sides of the block.
puke171
Kansas
Wes
427 Tall Deck
Okay, I didn't know that every thing I have ever worked on with a big block chevy in it has been two tons and up in grain trucks. Most of witch had to 427 tall deck in them and one with a 366. This is my first big block in a small truck. I knew the small block are on the side of the block.
I know the deck height, oilpan, intake manifold, distributor, carb, water pump, some of the brackets up front, and the pulleys are all a little bit different. Is there any other major differences between a tall deck and a standard 9.8 deck.
68post
Indianapolis
Tim
454, TBD
Only that the pistons have a taller height from the wrist pin to the crown - and that allows 4 rings to be used instead of the normal 3 rings.
Green79Scottsdale
G.R. - MI
Bob
Running a tall deck also may prevent you from running standard headers. You may be stuck with running manifolds. Also the throttle geometry and other things may be a little off too. You will find them as you progress through the build.
towjoe
Lafayette,IN
joe
78,80,81,81,86,88,89
K30's or V3500's
I have a 1980 k30 wrecker someone put a 366 tall deck in. I have a brand new crate 427 tall deck I keep entertaining idea of putting in my 1988 v3500 wrecker. Just have to buy a intake, stock motor mounts should bolt on the sides of it and not need that front mount.
drowe14
